wiring question
Old Dec 16, 2007 | 04:38 AM
charlie88's Avatar
Default wiring question
I have a ma audio 1000 watt amp and just got a single alpine type r 4 ohm 12 inch sub. I was wondering what the best way to wire this up on the sub itself and the amp? Thanks in advance.
Old Dec 16, 2007 | 05:11 AM
Fhe1079's Avatar
Bridge the 2 channels to the one sub
R+ and the L-
Old Dec 16, 2007 | 05:17 AM
charlie88's Avatar
what about the sub itself there are four connections? two possitive and two negatives. its a 4 ohm sub
Old Dec 16, 2007 | 05:54 AM
chucklescp's Avatar
is the amp a 2 channel amp or mono? what ohm is it stable at? are the type r's these SWR-1242D 12" Subwoofer (4Ω + 4Ω) or these SWR-1222D 12" Subwoofer (2Ω + 2Ω)? See if this helps you.
http://rockfordfosgate.com/rftech/wo...1&woofer_imp=3
http://rockfordfosgate.com/rftech/wo...1&woofer_imp=4
Old Dec 16, 2007 | 06:02 AM
charlie88's Avatar
its the 4+4 and i believe its a 2 channel amp
Old Dec 16, 2007 | 06:06 AM
charlie88's Avatar
i just dont want to blow anything so would i be safer running the 8 ohm or 2 ohm if i bridge the amp r+ to l-
Old Dec 16, 2007 | 11:18 AM
Fhe1079's Avatar
if the sub is 4ohms run it at that.
you only need 2 wires for the connection... RearRight(+) and the RearLeft(-) if its a 4 channel.
Old Dec 16, 2007 | 01:24 PM
charlie88's Avatar
so i could just run the wires to one set of connestion on the sub? there are four connections and they gave me jumper wires to run the sub at 8 ohms or 2 ohms which would be wiring the voice coils in series or parralel. i just need to know if i should run it at or four ohms to be safe and not blow anything.
Old Dec 16, 2007 | 03:01 PM
charlie88's Avatar
can anyone help me out here???
Old Dec 16, 2007 | 06:00 PM
Fhe1079's Avatar
Run it at 4ohms.... use a volt meter to check your wires to the subwoofer. All you need are 2 wires.
Old Dec 17, 2007 | 12:32 PM
chucklescp's Avatar
What are the specs on the amp or what model is the amp?
Old Dec 17, 2007 | 02:14 PM
charlie88's Avatar
well im almost positive its a 2 channel amp. i tried to look it up but the ma audio site will not work on my comp. its 1000 watts its the chrome looking one with the 2 handles and 2 gauges on it i dont know if your familiar with ma audio but i will try and look it up again
Old Dec 17, 2007 | 03:00 PM
chucklescp's Avatar
I am familiar with their amps, by gauges do you mean a digital screen on the front of the amp? Look on the chrome piece it should say a model number that will start with M or HK. let me know
Old Dec 17, 2007 | 03:55 PM
blazeplacid's Avatar
give me the model number of the amp and i wll help you out
Old Dec 17, 2007 | 03:59 PM
travis1041's Avatar
the amp u have is about 4 to 5 years old the ones that i remember like that are mono 1ohm stable but if your sub is a dual 4ohm i would run it at 2 ohm Parallel
Old Dec 17, 2007 | 04:00 PM
travis1041's Avatar
does it look like this one http://images.google.com/imgres?imgu...icial%26sa%3DN
bootlgr
Jan 26, 2016 01:22 AM
Greg S
May 28, 2015 12:46 AM
TotalChaos
13
Feb 4, 2015 10:24 PM
fearturtle44
15
Feb 13, 2004 01:15 AM
vpkb
12
Oct 8, 2003 04:17 AM
