Wiring harness problem
Old Dec 18, 2007 | 01:38 AM
GaTCLuvr06's Avatar
Default Wiring harness problem
I installed some LEDs to my daytime running lights and some 8500k 9005 and 9006 bulbs to my headlights. Now the harnesses are all fried and burnt up. Any reason why? And has anyone had electrical problems like this or anything similar?
Old Dec 18, 2007 | 02:00 AM
Macavely's Avatar
more watts then the wiring could handle.. what wattage are on thos bulbs? 100W ?
Old Dec 18, 2007 | 03:15 AM
DANIEL209's Avatar
Thats funny. I installed some H.I.D.s on my 06 tc and my power windows did not work then my moon roof would not open. I dont know they are pretty sensitive to anything.
Old Dec 18, 2007 | 04:14 AM
GaTCLuvr06's Avatar
yeah, they were 80 watts for the low beams and 100 watts for the high beams. the fuses were blown and the sockets are going to have to be repalced, but i cant seem to find a fuse to check for the parking lights. anyone know where it is?
Old Dec 18, 2007 | 05:55 AM
Macavely's Avatar
did you check under you dash right under the fuse relay door thing... you have to lay on you back and look up .. if its not there then its in the fuse box under the hood next to the battery .
Old Dec 18, 2007 | 11:25 AM
a_german_named_hans's Avatar
I always found that the easiest way to hook up electrical stuff up is to just run an individual circuit. Saves a lot of trouble.
Old Dec 19, 2007 | 03:08 AM
Zebman's Avatar
You need to run a ballast if you were not, which it sounds like. Everytime the bulbs ignited, they pulled far more current than the wires could pass. This heats and melts wires, and basically ***** up wiring harnesses.
Old Dec 19, 2007 | 03:24 AM
SquallLHeart's Avatar
he ran normal halogen bulbs it looks like... and no.. ballasts are for HIDs..
the problem is that the connection for the cheap crap bulbs he bought are poor, causing arcing and sparking within the plug.. which then creates heat and more resistance, which creates more heat... which creates more resistance.... repeat a few times.. and you got thermal runaway...
and then you got yourself a melted harness... btw, wattage doesn't play much in part here.
also.. parking lights run off the taillight fuse.
Old Dec 19, 2007 | 03:38 AM
Zebman's Avatar
I assumed that 8500k would indicate a measure of an HID bulbs temperature. Am I far off base?
Old Dec 19, 2007 | 03:51 AM
^^ yea thats what I thought. I'm confused.
Old Dec 19, 2007 | 03:54 AM
UNiT_xEr0's Avatar
DelMarVa
yeah that totally threw me off too.
Old Dec 19, 2007 | 03:56 AM
it indicates color temperature... it is not a specific term reserved for HIDs... it's for anything..
my assumption is he bought cheap halogen bulbs that have a high temperature indicative to those of HIDs.... however.. they are NOT HIDs... just "HID-bulbs"..... which are not HID....
cheap crap bulbs = bad connection = harness melting
Old Dec 22, 2007 | 09:22 PM
GaTCLuvr06's Avatar
you are right, there were just cheap ___ bulbs. put some good stuff in there that i have in my truck, and bingo no more problems
Old Dec 23, 2007 | 06:24 AM
well.. with some cheap butt bulbs.. you can try to improve it's electrical connection... i'd try some conductive grease next time around.
save you the trouble and money.... like most people out there say... save the money and do it right the first time... or else it might end up costing you much more in the long run
Old Dec 27, 2007 | 06:57 PM
trdsparks's Avatar
If the bulbs you got are 80W and 100W thats the reason why its frying your wiring. Factory wiring is only good for the OEM specs of 55W and 65W any higher than that could melt the wires.
skruff
May 6, 2015 08:32 PM
clickclickw00t
Feb 18, 2015 08:57 PM
FurionAlpha
Scion tC 1G ICE & Interior
Jan 12, 2015 08:25 PM
Scion_707
Dec 31, 2014 03:28 AM
oj411
Dec 15, 2003 11:57 PM
