Installed CAI and 9005 Lights, now blinker is really fast?
Old Dec 18, 2007 | 04:23 AM
dunnohow's Avatar
Default Installed CAI and 9005 Lights, now blinker is really fast?
After I had the CAI and bulbs installed, the blinker is now blinking really really fast, and I don't know why. How can I fix it to make it go back to normal?
Old Dec 18, 2007 | 04:29 AM
2_tC's Avatar
Usually that means one of your blinker bulbs is burned out.
Check to see if any of them don't work.
Old Dec 18, 2007 | 04:36 AM
dunnohow's Avatar
All of them work
Old Dec 18, 2007 | 08:35 AM
dunnohow's Avatar
also, i know this doesnt belong in this section but i installed the fujita cai inside a garage while it was raining outside and after the installation i drove it around for a bit andthe CEL turned on immediately . are there any common reasons for this after installing a cai?
Old Dec 18, 2007 | 11:34 AM
a_german_named_hans's Avatar
Check ur MAF. Make sure its plugged in correctly. If it is. Unplug it and see if its dirty maybe.
Old Dec 18, 2007 | 05:54 PM
megrog2's Avatar
For the blinker check the ground that was relocated under the driver's headlight.
Old Dec 18, 2007 | 06:05 PM
dunnohow's Avatar
sorry for all the questions im pretty new at this. so once i check the ground bolt what do i do with it?
Old Dec 19, 2007 | 12:07 AM
deflaytedwayz1's Avatar
what bulbs did you use? i know when i change the tails in my truck to led strips i needed to install a resistor or something because it was drawing a different amount of power and the car thinks it's broken. just an idea
Old Dec 19, 2007 | 06:04 AM
dunnohow's Avatar
yea i installed the 9005 high beam bulbs which use 65 watts instead of the stock 55 watt bulbs is there anything i can do about it? also, i didnt relocate the ground under the driver's headlight
Old Dec 19, 2007 | 07:17 AM
dunnohow's Avatar
9005 silverstar ultra's
Old Dec 19, 2007 | 07:26 AM
AcidDrop's Avatar
you touched something you wheren't suppose to cause when i did my high beams, yes there 65 watts as well my blinkers still seemed to blink the same. but yeah check your grounds and you might want to check that all your bulbs in plugged in properly.
Old Dec 19, 2007 | 08:21 AM
dunnohow's Avatar
i converted the 9005 ultras so they would fit in my lows. if i touched something i wasnt suppose to i probably wouldnt be able to fix it huh?
Old Dec 19, 2007 | 07:16 PM
AcidDrop's Avatar
there always is a way to fix/repair something. you mean you put the 9005 bulb in the 9006 slot or cut the wires and rewired them vise virsa? well even if the stock wattage is 55 for the low beams you can always add a higher watt and not mess something else up besides your wiring frying. a friend put 85 wattage bulb in his and there bright but hasn't had a problem since summer time.
Old Dec 19, 2007 | 07:31 PM
dunnohow's Avatar
i put the 9005 bulb in the 9006 slot
Old Dec 19, 2007 | 07:37 PM
AcidDrop's Avatar
oh then idk, unless you put a LED bulb then that causes it to blink faster, but just try putting a resistor so slow it down which is all i can think of for now.
Old Dec 21, 2007 | 01:04 AM
dunnohow's Avatar
i made a stupid mistake my friends and i forgot to plug in the front signal lights so now its all fixed thanks for the comments tho
xBSciontist
Jun 18, 2019 03:06 PM
hampton1100
May 28, 2015 07:32 AM
bruceb25
Nov 23, 2014 04:52 AM
TheRedBox
31
Dec 2, 2003 04:53 PM
deathcabforme
15
Oct 19, 2003 03:18 AM
