Got them walmart BLAZER fogs.. any info on installation??
Old Dec 18, 2007 | 05:32 AM
NewMexicoxBPhatBoy's Avatar
Default Got them walmart BLAZER fogs.. any info on installation??
Hey everyone, well i found the thread, probably very old about this BLAZER wallieworld foglights that fit into the little popout sections of the honeycomb grill, well i went and picked some up, but i dont know how im going to install them, i searched for them but i cant find it.. maybe im looking wrong? what i want is maybe a step-by-step guide on how to install them and where to hide all the wires?
any help would be greatly appreciated THANKS
Old Dec 18, 2007 | 06:20 AM
BlangKang's Avatar
Ok the install is pretty easy. What you need to do is first pop out the honey comb. Next you need to get the correct drill bit to drill threw the plastic. Maybe a 5/16ths or something along those lines. Just take the screw and put it up to the drill bits till you find the correct size. Next you gonna wanna put the fog light in the location you want. Leaving the fog light as is it will be hardto fit it in there, don't worry thats ok. Or you can simply measure the distance from the bolt on the fog light to the side of the bumper and the just drill. For me I just got a rough estimate and drilled. If your scared to eye ball it thats ok just bust out the tape measure and do the math. Next drill the hole, then put the fog light into location to verify that the location is correct. Once that is taken care of we can run the wires.
Now if you lazy like me I just ran 2 wires (one on each side) to the 12v supply on the running light (also the blinker) that way when you turn on your head lights (tech the parking lights) your fog lights will be on. The correct wire is the solid green wire. Run the power up to the solid green wire and tap it to it using wire taps. Next for the ground run a wire from the ground on the light to the bolts that holds the lip to the body. Its the only bolt on the lip thats closest to each bolt. Then your finished. Maybe someone has a link with photos but this isn't rocket science so take your time and you will be fine.
Also sorry is its hard to understand...this steel reserve has got the better half of me
Old Dec 18, 2007 | 07:40 AM
driveonfishboy's Avatar
I did the install and it's pretty easy. My only additional comment is to save the small piece of grill you popped out, cut it short, and grind it so that it slopes at an angle and fits behind the lights. That way it looks like the grill still continues behind the lights. Without it, it looks like the grill suddenly ends and that it didn't come that way. Good Luck.
Old Dec 18, 2007 | 01:36 PM
swartzautoman's Avatar
ill keep this in mind
Old Dec 18, 2007 | 02:31 PM
Puz06xB's Avatar
Here'e the thread:
https://www.scionlife.com/forums/vie...363&highlight=
Old Dec 18, 2007 | 04:52 PM
Grime's Avatar
Originally Posted by Puz06xB
Yeah, read page 13 for a good install guide
Old Dec 19, 2007 | 02:12 PM
aight, thanks you guys, i FINALLY get time this afternoon, my classes get out half a day today to start the Christmas Break (Still got work, but not till tonight) so im gonna be installing these @ about 1:00 ill be sure and post pics of how it came out ;)
Old Dec 19, 2007 | 09:52 PM
Default ____ED OFF!! :(
Okay, ive been outside for 3 hours now! and i got everything all lined up, hooked up, and when im like WOO finally get to see how bright they are, bam, they wont turn on!! so im like okay, musta hooked something up wrong, nope i checked all the wiring 3 times and its all correct, only thing is THE FUSE!! okay so i run and buy a 5 pack of fuses try 1, try 2, try 3, pretty soon the whole pack GONE, all of them burned.. so if ANYONE has any idea on what i may be doing wrong, PLEASE post it here, i want them on before sun down (2 1/2 hours)
Old Dec 19, 2007 | 10:03 PM
06scioxb's Avatar
Team XcelsiA
Team Sushi
to much juice is what you are pulling also what kind of fuse size amp wise use a 40amp try it but it might also pop also where is your 12volt coming from
Old Dec 19, 2007 | 10:09 PM
The Fuse says its 15....and the 12volt? would that be the grounding? i got one on the + battery terminal, and one underneath my dash and the other two that come right outta the fogs themselves i have one on the radiator support, and also on the other side i got the same thing.... the one that has the fuse in it, (The grounding wire) it says i can either put it into the fuse box (I have no idea which fuse to put it in:S) or either the + terminal on the battery, so i thought the + part would be ALOT easier
Old Dec 19, 2007 | 10:32 PM
06scioxb's Avatar
Team XcelsiA
Team Sushi
+ to battery and negative to chasis
red= +
black = negative
are these to a switch or just to your running lights
Old Dec 19, 2007 | 10:37 PM
Okay ...negative would be the white colored wire? and the black wire would be the one going onto the + wire terminal eh? cause thats where i got ti, on the red side.. and yes it is for s Switch, not directly to my running lights..
Old Dec 20, 2007 | 03:32 AM
06scioxb's Avatar
Team XcelsiA
Team Sushi
nah man you have it all wrong black will always be negative that is why you keep on popping the fuse thw white one is 12 volt
Old Dec 20, 2007 | 03:56 AM
Gothbox's Avatar
yea that sounds like your prob.
Old Dec 20, 2007 | 04:39 AM
Okay, tried that, it blew it again, but with my NOOBish mind what i didnt do was, there is a little black wire that you connect to the switch/GROUND and that is if you have it wired up to the headlights.. so ME i had that hooked in, but i didnt need to!! i looked over the instructions 1 more time, and i was like okay, this little wire is (G) and all it says to hook up is wire (A) (B) and (C) so i took it out, and VOILA!! they are BRIGHT AS HELL!! i love them thank you very much for your advice anyway, ill get pics later, too damn cold out right now, lol..
Old Dec 20, 2007 | 01:17 PM
Puz06xB's Avatar
It's cold in New Mexico?
Old Dec 21, 2007 | 03:24 AM
^^^^^^^^^^^ you'll be surprised at what else happens here..haha
Old Dec 24, 2007 | 07:54 PM
maxpain's Avatar
Post some pics up
Sooby
Scion tC 1G Wheel & Tire
11
Apr 8, 2020 11:51 PM
SkillFreeJake
Scion tC 2G Aero & Exterior
Jul 27, 2015 12:34 AM
randomsuper
20
Jun 13, 2015 10:56 AM
Frustratez
Feb 26, 2015 04:03 PM
TheRedBox
31
Dec 2, 2003 04:53 PM
