06 xB 12 volt wire codes
Old Dec 18, 2007 | 12:58 PM
swartzautoman's Avatar
Default 06 xB 12 volt wire codes
im not sure if this has been posted befor, don't yell at me, im just trying to share some usefull info.
12volts wht/blue (40A), wht/red (15A) + ignition harness
Starter black + ignition harness
Second Starter N/A
Ignition black + ignition harness
Second Ignition black/yellow + ignition harness
Third Ignition N/A
Accessory blue/red + ignition harness
Second Accessory N/A
Keysense yellow - ignition harness
Power Lock blue/white - driver kick, 14 pin plug
Notes: Meter this wire while turning the key in the driver door key cylinder.
Power Unlock yellow/black (double pulse) - driver kick, 14 pin plug
Can also use the passenger door key cylinder wire for unlock, which only requires a single pulse. It is blue/red (-) in the passenger kick in a 14 pin plug.
Lock Motor blue/orange 5wi driver kick, 9 pin plug
Unlock Motor yellow/green 5wi driver kick, 9 pin plug
Parking Lights+ green + headlight switch
Notes: Also found at the top of the fuse box in a 13 pin plug.
Parking Lights- N/A
Hazards green/orange - hazard switch
Turn Signal(L) green/black + top of fuse box, 13 pin plug
Turn Signal(R) green/yellow + top of fuse box, 13 pin plug
Reverse Light red/black + top of fuse box, 9 pin plug
Door Trigger red/white - top of fuse box, 9 pin plug
Dome Supervision use door trigger wire
Trunk/Hatch Pin common with door trigger wire
Hood Pin N/A
Trunk/Hatch Release brown/yellow - driver kick, harness to rear
Notes: Meter this wire while opening the hatch from the handle on the rear hatch.
The hatch release motor wire is blue/yellow (+) in the driver kick, harness to rear.
Power Sliding Door N/A
Factory Alarm Arm N/A
Factory Alarm Disarm N/A
Disarm No Unlock N/A
Tachometer black ac data link conn below fuse box, pin 9
Wait to start N/A
Brake Wire green/red + brake pedal switch
Parking Brake black - parking brake switch
Horn Trigger white/red - horn switch
Memory Seat 1 N/A
Memory Seat 2 N/A
Memory Seat 3 N/A
Radio 12v blue/yellow + radio harness
Radio Ground white/black - radio harness
Radio Ignition gray + radio harness
Radio Illumination green + radio harness
Factory Amp Turn-on N/A
Power Antenna black/red + radio harness
LF Speaker +/- pink - purple +,- radio harness
RF Speaker +/- lt. green - blue +,- radio harness
LR Speaker +/- black - yellow +,- radio harness
RR Speaker +/- red - white +,- radio harness
Parking Lights- N/A
Headlight black/white - headlight switch
Speed Sense purple/white radio harness
Wipers gray (L), black/red (H) + windshield wiper switch
LF Window up/dn red/blue - green/white A driver window switch in door
RF Window up/dn red/blue - green/white A driver kick, 9 pin plug
LR Window up/dn red/yellow - green/yellow A driver kick, 4 pin plug
RR Window up/dn red/black - green/black A driver kick, 4 pin plug
Sun Roof open/close N/A
Sun Roof Limit/close N/A
Memory Seat 1 N/A
Memory Seat 2 N/A
Memory Seat 3 N/A
Old Dec 18, 2007 | 01:25 PM
Zsanz's Avatar
got it for the 08 model )
Old Dec 18, 2007 | 01:30 PM
no, sorry.
ill keep looking
Old Dec 18, 2007 | 04:20 PM
D_M_A_N's Avatar
good info, Im' going to bookmark this page :D
Old Dec 29, 2007 | 07:56 AM
CREEPINGONCHROME's Avatar
thats easy info to find
Old Dec 29, 2007 | 08:16 PM
snowromance's Avatar
great info. thank you. last time i was installing my tail lights i couldnt find the post that had some of this information already and i didnt feel like sitting and searching the forum for a half hour looking.
i just saved this to a notepad document for future references. THANK YOU.
zzbear
Apr 19, 2015 06:18 PM
nightfox915
Apr 17, 2015 07:06 PM
stillcole
Scion tC 2G ICE & Interior
Apr 6, 2015 03:42 PM
DAHOZZMAN
Dec 16, 2014 06:48 AM
Inazuma
Feb 22, 2004 02:44 AM
