second, third and fourth mods done this past week
Old Jan 2, 2008 | 12:36 AM
twotoastyboxes's Avatar
Default second, third and fourth mods done this past week
ok everybody here's the pics and step by step of the mods we've done. If you recall my first one was the engine bay...
Now we've moved to the interior. To start with we did the piece around the radio.
Here are pics showing the break down of the air vent.
[/img][img][/img]
[img]
[/img]
[img]
Here are the pieces painted and reassembled...
[/img]
[img]
[/img]
[img]
[/img]
[img]
[/img]
[img]
here's the finished piece before installing it back into the car
[/img]
Now in the car
[img]
[/img]
the next mod was the gauge cluster cover and the outer air vents. The next few pics are of the gauge piece taped and ready to be painted.
[img]
[/img]
here are pics of it partially painted and one of the air vents
[img]
[/img]
here it is installed and fully painted...
[img]
here are pics of the door tweeters...didn't get step by step but they just pop out.
[/img]
[img]
[/img]
and finally the grounding kit
[img]
first off we mounted the wire to the passenger side shock tower. Then to the top of valve cover, then all four coil packs, also from the shock tower to the bolt on passenger side headlight in center section of the grill...
[img][/img]
[img]
From the last coil pack we went to a grounding block. From the drivers side head light location we went to the battery negative , also from the negative to the grounding block. From the grounding block to the shock tower and from there to the fire wall.
[/img]
[img]
[/img]
[img]
[/img]
[img]
Hope this was helpful.... it sure was a pain in the A$$ loading all these pics. Next time we wont wait to pile up 3 or 4 mods before we post.
Any and all feed back welcome.... [/img]
Old Jan 2, 2008 | 01:52 AM
lvbitwiz's Avatar
wow, that's a lotta pink! nice job though
Old Jan 2, 2008 | 03:58 AM
Fuzi0nX's Avatar
im going to try not to do anything that would take alot of work to return my car back to the stock look should I decide to sell it years down the road.
I like it though, I did something similar to the interior of my integra.
Old Jan 2, 2008 | 01:29 PM
swartzautoman's Avatar
looks good.
take your time, do it right, and you will always be happy with it.
Old Jan 2, 2008 | 04:29 PM
cherry-8's Avatar
Now everything matches your coolant.
Cool.
Old Jan 2, 2008 | 04:40 PM
ibnboxin's Avatar
ok not that this matters. but i would be willing to bet you might want these unless you already have them.
https://www.scionlife.com/forums/viewtopic.php?t=177458
by the way nice job on the mods. remembered seeing the rim and remembering someone on the forums was doing pink mods. so thought i would post you a link
Old Jan 3, 2008 | 12:17 AM
jimmbomb's Avatar
jh
Old Jan 3, 2008 | 12:43 AM
I would love these rims if the came in hot pink instead of the baby pink... not "shocking" enough...
Old Jan 3, 2008 | 01:07 AM
CIONIDE's Avatar
Those were a special edition for the tC, you'll note the specs:
The specs are:
17x8"
5x100 bolt pattern
+40mm offset
Pink w/ polished lip
But if you go to their site:
http://www.jlbmotorsports.com/rims/konig-list.html
they have a Konig Britelite listed as 17x7 @ 40 offset available in 5x114.3 bolt pattern. It's listed as Red with Machined Lip, but looks more Pink to me. Hub bore is 73.1mm, so you will need hubcentric adapters.
More power to the lady in pink! Keep those mods a comin'!
Old Jan 3, 2008 | 01:14 AM
Too red....I'll keep looking Thanks
Old Jan 3, 2008 | 01:36 AM
jimmbomb's Avatar
Hows about this color wheels.. granted, this person suffered misfortune, but look at those wheels!! ya think, twotoastyboxes???? jh
http://www.clubxb.com/forums/f42/166...lert-viet-box/
Old Jan 3, 2008 | 09:51 PM
now that's what I'm talking 'bout jimmbomb! Wonder where they got them custom painted that color.
Old Jan 5, 2008 | 04:21 AM
jimmbomb's Avatar
Well all long as you're going pimp PINK.......
http://clubstlscion.com/forum/forum_...?TID=5499&PN=1
Ya may as well do your gauges too.. these pics are of a 07 Scion TC,
I think with the correct gauge face overlay & Pink LED's , yours should look great!!!
Then drop pinks into your H/VAc panel & do your P R N D S + - panel as well......
Send your H/U to Garage 151 & have them LED swap your stereo to all pink something to think about
.. jh
Old Jan 5, 2008 | 08:19 AM
ibnboxin's Avatar
two toasted
i am willing to bet this is where they got the paint. http://www.carizzmacolors.com/paints.htm
Fuschia Pearl is the color they used on those rims ( ok so he posted the colors.
i would say get some rims and talk to a body shop about painting them. if you could prep them before hand and have the body shop do the paint and touch up.
Old Jan 6, 2008 | 04:07 AM
DJ_FroZone's Avatar
so why did he need gorunding in the engine?
Old Jan 6, 2008 | 05:55 PM
Often improved idle and drivability are obtained as the additional grounding points equalize resistance and voltage between various ground points. It also prevent power loss and ensure top performance of your ignition and other components
Old Jan 11, 2008 | 04:34 PM
thumper_1151's Avatar
looks nice
8URAWD
May 2, 2018 02:22 PM
Marganne
Apr 3, 2015 06:52 PM
LzeroKI
Feb 20, 2015 12:31 PM
cid_mcdp
Jan 5, 2015 02:45 PM
