brakes going already?
Old Jan 4, 2008 | 09:44 PM
brettalesi's Avatar
Default brakes going already?
Ive had my xb for just over 6 months now. just recently I heard my brakes squeaking. I only have 9900 miles on the car and it just seems a little soon for the brakes to me going. any suggestions?
Old Jan 4, 2008 | 10:53 PM
Bigfieroman's Avatar
Take it to the dealer...I think wear items only have a 10k or 12k mile warranty.
Old Jan 5, 2008 | 12:03 AM
bugtoxb's Avatar
mine squeak from time to time, only noticed when wet out.
Old Jan 5, 2008 | 01:01 AM
Sasnuke's Avatar
Brake squeak does not necessarily mean worn out. It might just need servicing (cleaned & lubricated).
Old Jan 5, 2008 | 01:09 AM
CIONIDE's Avatar
Lubricating the brakes???? It just doesn't sound right when you talk it out.
Old Jan 5, 2008 | 06:30 PM
Sasnuke's Avatar
Well I guess its where you put the lubrication, on the friction surface "bad", on the "ears" of the pads, "good". From my experience most brake noise comes from a slight rust buildup on the edge of the rotor rubbing against the pad edge like a tuning fork, hence the noise. Often sanding the pad surface ever so slightly & machine the rotors (if not replacing) will cure the noise. Adding lubrication between the pad shims & the back of the pads, also on the ears of the pads will help reduce any chance of noise occurance leading to many miles of quiet braking.
gqdabien
Oct 8, 2015 05:36 PM
Klashan
Sep 24, 2015 12:39 PM
DannyBoy65
Sep 21, 2015 06:23 PM
axB
Sep 18, 2015 06:11 AM
Subaru86
Scion FR-S Aero & Exterior
Sep 14, 2015 12:39 PM
