2008 Projector cutoff fix
Old Jan 15, 2008 | 12:49 AM
t_urbo_C_harged's Avatar
Default 2008 Projector cutoff fix
could anyone that has done this put up some steps on how to fix the cutoff of the projectors with HID's or is there really no way unless you get new projectors???
Old Jan 15, 2008 | 02:28 PM
dos_techie's Avatar
What do you mean by "cutoff fix"? Projector headlights are designed to have a cutoff.
Old Jan 15, 2008 | 02:30 PM
ADRdesignCo's Avatar
apprently from what ive seen there is still a little light shining above the normal cut off on the 08 projectors.
Old Jan 15, 2008 | 03:47 PM
MyTightRide's Avatar
I guess I've been asleep...when did Scion change the body style on the tC? What changes were made?? I need caffene.....
Thanks,
Glenn
BilletMyRide.com
Old Jan 15, 2008 | 04:26 PM
dos_techie's Avatar
I have an '08 with projectors and have no problem with the cutoff.
Old Jan 15, 2008 | 06:47 PM
o8tC's Avatar
i have an o8 with HIDs. all you gotta do is lower the lights
Old Jan 15, 2008 | 07:09 PM
Which HID kits are you chaps buying and from where?
Glenn
BilletMyRide.com
Old Jan 15, 2008 | 07:46 PM
o8tC's Avatar
operatic's form 3bspec.com. 140 buck shipped overnight
Old Jan 15, 2008 | 08:42 PM
enjoithis's Avatar
I know what your talking about, leave it who cares, its not in your eyes
Old Jan 15, 2008 | 10:01 PM
hawgs74's Avatar
The only way to fix the "ghosting" would be to swap the projector lense with one from a TSX or 350Z. AKA retrofit.
However u can fix the squirrell spotters by bending down the little metal tab inside.
Old Jan 15, 2008 | 10:12 PM
Aroddalobster's Avatar
i'm running 6000k mobile hids in my 08 projectors. just get a phillips and an open wall and lower the beam a bit.
Old Jan 15, 2008 | 10:18 PM
hawgs74's Avatar
Yup -- people forget that the 08's are not made for HIDs. Just a better option than most for the tc. No matter how much "aiming" you do U will still not have a crisp sharp cut off with 08's. PERIOD.
Old Jan 15, 2008 | 11:23 PM
thats what I was asking, how to make the cutoff crisp and sharp... well I guess now I know that the only way I can do that is to get a new lense... but what about the cutoff shield? I heard there were problems with that too...
Old Jan 15, 2008 | 11:50 PM
I prefer just to drive with my high beams on all the time.........
Glenn
BilletMyRide.com tC Projector Headlights
Old Jan 16, 2008 | 02:26 AM
deez's Avatar
ugh coolll....... i have the 8000k in my 08's.. did a little adjusting, very minimal now
Old Jan 16, 2008 | 04:04 AM
The HID's you talked about - operatic's form 3bspec.com. 140 buck shipped overnight - are those the simple plug into the headlight wiring harness of your car? Or, do they have the cable that runs to the battery with the fuse, low-voltage relay that is triggered by the headlight switch? That's the style I'm looking for....
Glenn
BilletMyRide.com
Old Jan 16, 2008 | 04:08 AM
enjoithis's Avatar
Glenn
BilletMyRide.com
DONT GET THAT KIND THEY ARE KILLERS! Believe me, people pay EXTRA for that harness for a reason! I do automotive electronics and you want that relay becasue HID's draw much much much more power than standard bulbs! Mobile H.I.D. is the way to go
Old Jan 16, 2008 | 04:12 AM
Glenn
BilletMyRide.com
at startup they draw much more power... then they run at less wattage once on (35 watts as opposed to 55watts)
Stephen
Old Jan 16, 2008 | 08:08 PM
DigitalReaper's Avatar
I haven't looked at my headlights, but can you fix the squirrel spotter issue without taking the headlights out or opening them up.? Any pics of this process.?
Old Jan 18, 2008 | 11:04 PM
yes here is a link (I know it is a toyota site but it is the same for us)
http://www.toyotanation.com/forum/sh...=192949&page=4
you can just either bend the tab down (inside the projector bend the little tab down to cover the whole) or you can do the jbweld like the guy on that forum did...
