2008 Projector cutoff fix
could anyone that has done this put up some steps on how to fix the cutoff of the projectors with HID's or is there really no way unless you get new projectors???
I guess I've been asleep...when did Scion change the body style on the tC? What changes were made?? I need caffene.....
Thanks,
Glenn
BilletMyRide.com
Thanks,
Glenn
BilletMyRide.com
The only way to fix the "ghosting" would be to swap the projector lense with one from a TSX or 350Z. AKA retrofit.
However u can fix the squirrell spotters by bending down the little metal tab inside.
Originally Posted by ADRdesignCo
apprently from what ive seen there is still a little light shining above the normal cut off on the 08 projectors.
I prefer just to drive with my high beams on all the time.........
Glenn
BilletMyRide.com tC Projector Headlights
Glenn
The HID's you talked about - operatic's form 3bspec.com. 140 buck shipped overnight - are those the simple plug into the headlight wiring harness of your car? Or, do they have the cable that runs to the battery with the fuse, low-voltage relay that is triggered by the headlight switch? That's the style I'm looking for....
Glenn
BilletMyRide.com
Glenn
BilletMyRide.com
Glenn
BilletMyRide.com
Glenn
BilletMyRide.com
Glenn
BilletMyRide.com
Glenn
BilletMyRide.com
Stephen
yes here is a link (I know it is a toyota site but it is the same for us)
http://www.toyotanation.com/forum/sh...=192949&page=4
you can just either bend the tab down (inside the projector bend the little tab down to cover the whole) or you can do the jbweld like the guy on that forum did...
