Permanent marker... Anyone?
Old Jan 17, 2008 | 05:03 PM
frenchaj09's Avatar
Scion Noics
Default Permanent marker... Anyone?
So this CRAZY ___ %^&$* wrote an obscenity all over my car, with permanent marker.
Wondering: Any solvent or any sort of magic short of a miracle gonna help me avoid paying over 7000 for new body panels?
let a brother know...
Im gonna kill her.
-Sb
Old Jan 17, 2008 | 05:07 PM
unxpectederror's Avatar
try alcohol
ack154's Avatar
Have you tried calling a body shop to see what they'd recommend doing? They might know of something that would easily buff it out.
Also, have you filed a police report? I know I would... especially if you have any idea at all who might have done it.
Old Jan 17, 2008 | 05:09 PM
davedavetC's Avatar
maybe a clay bar?
Old Jan 17, 2008 | 05:43 PM
WAlterEgo's Avatar
ah...that sucks to hear. alcohol may work, but i heard on clothes. maybe mr. clean magic eraser? may damage the surface
Old Jan 17, 2008 | 05:46 PM
CRUZtc8's Avatar
use acohol and try scrubing it with mr. clean magic eraser.
Old Jan 17, 2008 | 05:53 PM
rivas_203's Avatar
hmm i dont know if the same concept works on clearcoat, but i heard that on a whiteboard if someone writes with sharpie, write over it with dry erase marker and it'll wipe off with a dry eraser.
Old Jan 17, 2008 | 06:01 PM
gtran1502's Avatar
Would WD-40 affect the clear coat? If not, use that.
Old Jan 17, 2008 | 06:31 PM
markritch's Avatar
i would give it a good once over with a claybar...maybe 2 washes after that
Old Jan 17, 2008 | 06:47 PM
frame's Avatar
I dont know if it'll work the same on the car but it does on a white board. Its a trick i read somewhere, tried it out and it actually works.
If someone writes on a white board with a permenant marker , you just write over it with a dry erase marker and erase as usual and it comes off. again not sure if it'll work on the car and whether the eraser will put scratches on the paint.
i would try it with a towel or something
Old Jan 17, 2008 | 08:49 PM
O5_TRD_tC's Avatar
^^that does work for sharpies
Old Jan 17, 2008 | 08:58 PM
RCZDesigns's Avatar
Definately don't use the magic eraser. Especially on a BSP. You will have gnarly swirl makes everywhere.
A friend of mine had this happen to him, and he gave a detailer $20 and they buffed his whole car back to brand new, taking off the marker and all. Buffing is the least abrasive method IMO.
Old Jan 17, 2008 | 09:03 PM
xDevious's Avatar
turtle makes a slightly abrasive paste that might take it off, it's called rubbing compound. I drove through spilled paint with my old car and it took it right off. you can get it at walmart or any auto parts store and it's under $10. Worth a shot.
http://www.turtlewax.com/main.taf?p=2,1,4,13
Old Jan 17, 2008 | 09:07 PM
trentonm's Avatar
the sharpie/dry erase market would be the lease abbrassive start. And a buck for a marker and a use a soft terry clothe to wipe it off would be a golden start. Dry erase markers work on a lot of things... and I dont see why the same concept cant be used on a clearcoat.
Old Jan 18, 2008 | 12:24 AM
scionteecee's Avatar
dat really sux dawg. i would try buffin its da best bet.
Old Jan 18, 2008 | 12:55 AM
MR_LUV's Avatar
Administrator
Administrator
Default Check out GOOF OFF 2...
Sorry to Intrude.
It's good for Crayons, Markers, Tar, Grease, Grime, Dried Latex Paint and most stains & spots.
Also works on removing decals, stickers, adhesive residue.
Water-based multi-purposer remover. Better than hazardous solvents. Non-abrasive than clay bar, rubbing compound.
Works most hard surfaces like counter tops, tires, wheels, vinyl tops, metal glass, brick, concrete, wood.
Also for most fabrics, upholstery, and carpets.
Comes in a orange 22 fl. oz. sprayer.
Something about $8-$9 at Home Depot.
MR LUV
Old Jan 18, 2008 | 01:05 AM
MrBurrito's Avatar
what did u do to her? haha
Old Jan 18, 2008 | 01:57 AM
thespottedcow's Avatar
goof off is bad for the paint, you could try goo gone, that ones fine for paint
*I believe*
Old Jan 18, 2008 | 02:11 AM
BZinn1's Avatar
denatured alcohol and then wash and wax and polish.........call a few shops that do detailing and they may even have a product on hand that will work..........
Old Jan 18, 2008 | 01:29 PM
MeatRocket's Avatar
x2
