trying to install xm
Old Jan 19, 2008 | 02:44 PM
Archngl's Avatar
Default trying to install xm
i have the stock 06 unit, and don't want to use the fm transmitter, what cable do I need to plug it in?
-i'd like cheap if possible.
would this work?
http://cgi.ebay.com/ebaymotors/PIONE...spagenameZWDVW
or this?
http://cgi.ebay.com/NEW-PIONEER-IP-B...QQcmdZViewItem
Old Jan 22, 2008 | 10:23 PM
rrusk9's Avatar
I installed a Terk XMDTLK into my '06 box. I think I found it for less than this, but you can get it for $166 here: http://techronics.com/index.cfm?fuse...5630&aff=72182
Note that this is a full-blown XM receiver that hides within the dash and is controlled via the factory stereo controls, not just an adapter cable for an ugly external XM receiver.
Works fine. Controls are just like factory. The text displayed is shorter than the LCD display, which is annoying and probably doesn't happen with the factory unit. I'll take the money in pocket instead, though.
The antenna is magnetic. I mounted mine just ahead of the hatch in the middle of the back edge of the roof. A lot of the interior had to come loose to run that cable well. There is a little bit of wire visible between the hatch and the roof.
The cables will connect cleanly to the back of the radio. However, I got a bit picky in mounting the two electronics boxes and ended up taking the top off the dash. There are two existing electronic boxes mounted on sheet metal brackets there. I tie wrapped the two new boxes to those, no rattles and everything is out of the way.
A number of stores are listing this device as discontinued, but there are still a few online vendors selling them.
Old Jan 22, 2008 | 10:28 PM
rrusk9's Avatar
Default Re: trying to install xm
I just noticed that there is a rebate on these right now through some vendors. It's $149.99 after rebate at http://store.xmfanstore.com/texmfortovex.html.
Old Jan 22, 2008 | 10:44 PM
Archngl's Avatar
picked up something from circuit city for 30.00.
I can't use the hu to control it, but the xm radio I got came w/ a remote, so it all worked out!
Old Jan 24, 2008 | 03:36 PM
adamisbomb's Avatar
yeah i have an external xm display on the wifes xb. its mounted right above the lil cubby in from of the passenger. i would have liked to hardwire, but the money was an issue.
Old Jan 27, 2008 | 01:40 AM
combatsteve's Avatar
neither of those will work for the stock unit. Those pieces are for xm ready aftermarket pioneer units. What you probably would want to get is a wired Fm modulator.
http://www.circuitcity.com/ssm/Audio...oductDetail.do
Old Jan 28, 2008 | 10:21 PM
adamisbomb's Avatar
how do the wired fm modulator works. one plugs into your antenna hole, one to the xm? what about the power adaptor in the pic. im lost
Old Jan 29, 2008 | 02:00 AM
the xm antenna wire plugs into the fm modulator then the antenna from the modulator plugs into the xm receiver. Also you unplug the antenna out of your radio and plug it into the modulator and then plug the antenna end out of the modulator into your radio. Then you tune the radio to the frequency that the xm in broadcasting at. As for the power adaptor it is so you can have the cig lighter plug plug in behind the dash and not into the cars cig lighter.
SuBSiN
Mar 13, 2015 04:02 AM
randomsuper
Feb 27, 2015 01:29 AM
Frustratez
Feb 26, 2015 04:03 PM
ofgarcia
Dec 22, 2014 12:27 AM
TheRedBox
31
Dec 2, 2003 04:53 PM
