extreme dimensions f1 lip kit fitment?
Old Jan 24, 2008 | 04:59 PM
BangorXB's Avatar
Default extreme dimensions f1 lip kit fitment?
did a search, came back with a few things.
basically i just wanna know how the sides fit? alot of work to get them right?
thanks
Old Jan 25, 2008 | 02:12 AM
greenguyshrek's Avatar
I had the kit and it fit pretty good. the front fit perfect. the rear was a little harder the shop molded it to the stock lip. the skirts fit good they just used brackets under the car to keep it sturdy.
Old Jan 25, 2008 | 04:47 AM
TerribleTed's Avatar
The fits are about like you say. Brackets custom made for the bottoms is a good idea. I do not like the way they mount to the top of the rockers in the door jambs (assumingly with double stick tape). I modified my stock side skirts and mounted the F-1 skirts to them. I then mounted the assemblys to the car using the stock skirts fasteners. My side skirts do not protrude in to the door jambs they mount flush to the outside of the rockers like the factory pieces did. I purchased 3 new rubber sealing strips from Scion for the edge to the body. The top edge of the new skirts is a few inches longer than the stock pieces, so, the third rubber seal is cut and small sections used on each side to complete the run. I did not used the fasteners that are under the covers in the sides of the stock pieces, Instead I added 2 screws into each wheel opening (front and rear) to secure the ends of my skirt assemblies.
I feel the front is a little weak without lower brackets. I fabricated lower brakets like the factory plastic ones with sheet steel. These are screwed between the bottom of the lip and the factory bracketing locations.
Old Jan 25, 2008 | 04:58 AM
Just1n's Avatar
Wagonistas
Where would you suggest to go to get the best kit? ^^
Old Jan 25, 2008 | 09:46 PM
That my friend is a very good question.
Old Jan 28, 2008 | 05:09 PM
BangorXB's Avatar
thank u for the info guys. i appreciate it very much
r2photography
Jun 17, 2015 08:48 AM
SilverBulletTC
Scion tC 1G Aero & Exterior
Apr 3, 2007 10:35 PM
sciontc313
80
Feb 24, 2006 04:54 AM
scionlife
Jan 3, 2006 11:43 PM
tCtunerZ
38
Nov 7, 2005 04:12 PM
