Serious question....i need some advice...!
Old Nov 10, 2004 | 03:44 AM
unlimited77's Avatar
Default Serious question....i need some advice...!
Ok i would like by starting to describe the problem of my tc.
I had it for about 4 months now...and it had 5200 miles on it....I changed the oil at 1451 to mobil 1 5w-30 syn.
After 2100 i took the car to 4500 to higher and i am hearing this noise from the engine....
Ok i had heard alot of noises but none like this....Its very faint and seems like everytime i go near 4200 i hear like a chi chi chi sound...almost like a chirping sound...
I was thinking it might be the intake or might just be a tc thing
or it might be vvt-i.....but i didnt think vvt-i made any sounds..
Any input is thankful...and no i never made post where i complained about noise so i know its not from a exterier car part...haha so dont make those assumptions, unless it makes a sound at higher rpms...
I will test it out more tomm....but as you can tell i have came along ways to 5200 without revving my car...
Old Nov 10, 2004 | 03:56 AM
tCholleration's Avatar
so it's like a high-pitched noise??....
Old Nov 10, 2004 | 04:06 AM
lucky's Avatar
Strictly Scionized
"Any input is thankful"
Your post might be less confusing if you edit it to make a distinction between RPM and mileage in the numbers you refer to.
Old Nov 10, 2004 | 04:18 AM
putz's Avatar
take it to the dealer. have them check it out.
Old Nov 10, 2004 | 04:32 AM
blastedat9's Avatar
Team XcelsiA
i think the tC has a valve in the exhaust that opens up at higher RPMs to allow freer exhaust flow to increase power. what you're hearing could be because of this. if thats the case then its perfectly normal. does it always start making the noise at exactly the same RPM?
Old Nov 11, 2004 | 02:24 AM
Yes it makes it at a certain rpm.....but also at different points.
I am sorry for the confusing topic...It is not a high pitch noise.but kind of sounds like a bov all muffled up.
Old Nov 11, 2004 | 02:29 AM
ScionBandit's Avatar
sIcKsCiOnS
DelMarVa
Scion Tuners
could be number of things
take it to a dealer, test drive with them as you drive and when you hear it ask them if they hear anything....try and take a technician with you, helps
Sgtfluffy16
Regional - Northeast
Jul 28, 2021 10:32 PM
eujin
Feb 23, 2016 01:18 AM
Sgtfluffy16
Sep 30, 2015 01:42 PM
jeremydoc
Sep 16, 2015 11:31 PM
x2x3
Jul 12, 2015 12:44 AM
