dash
Old Jan 26, 2008 | 06:47 PM
mnscionxb's Avatar
Default dash
how hard is it to get the dash out i want to put some leds in my blower vents
Old Jan 26, 2008 | 06:57 PM
SquallLHeart's Avatar
just start yankin pretty much.
scions come apart like legos.. with a few screws here and there.
Old Jan 26, 2008 | 07:05 PM
miketf1's Avatar
couldnt have put it better myself. before you yank out pieces that are under other pieces just look around for screws. i know that may not make sense, but when you start pulling the dash apart it will make sense...
Old Jan 26, 2008 | 07:26 PM
onemorescion's Avatar
DelMarVa
Scion Tuners
There is a DIY tutorial on the LED swap for the dash lights. Search and you will find.
Old Jan 26, 2008 | 07:33 PM
JohnathonSull's Avatar
I took mine simi-apart and installed LED's in my a/c vents. Wasn't to difficult. Took a solid day to get it done for me.
Old Jan 26, 2008 | 11:14 PM
lvbitwiz's Avatar
Default Re: dash
1. remove neg battery cable and then pop off the a pillars
2. remove radio bezel and trim around cluster
3. pull the radio, instrument cluster and the screws where the trim and bezel were
4. remove glove box and remove nut holding the passenger airbag in place (up behind where the glovebox was)
5. lift out dash
Old Jan 27, 2008 | 12:33 AM
Yea, I didn't find where that airbag bolt was at until I had finished everything. Next time it'll be alot easier once that bolts out
Old Jan 27, 2008 | 03:22 AM
lvbitwiz's Avatar
the fur confused you
Old Jan 27, 2008 | 05:04 AM
That or breathing in the glue
Old Jan 27, 2008 | 06:32 PM
jakalope's Avatar
lets see some pics from you guys that have done the led vents any helpfull hints on the install???
Old Jan 27, 2008 | 10:22 PM
mnscionxb's Avatar
yes and how many in a vent? is 1 or 2 plenty or should i order more?
Old Jan 28, 2008 | 08:05 PM
I personally only used 1 Super bright LED from oznium in all four vents and it lit it up good enough for me. When it gets darker out I will try and take some pics. I'm going to put an LED into the passanger side defrost vent when I take the dash out here in a couple of weeks, along with sticking two cathodes up in the front window defrost vents.
Old Jan 29, 2008 | 01:22 AM
mnscionxb's Avatar
cool i got 4 sets of purple cathodes and 10 red superflux 4 chip red
Old Mar 8, 2008 | 01:18 AM
Amaran06's Avatar
so your telling me there is only one nut holding the whole dash?? wut about the other side driver side no nuts??
BlingSlade
Oct 19, 2016 12:39 AM
prescottn
Scion tC 2G ICE & Interior
Apr 26, 2016 01:14 AM
prescottn
Oct 8, 2015 05:31 PM
gqdabien
Sep 17, 2015 09:23 PM
OpTicaL
Sep 16, 2015 10:25 AM
