2-way remote start alarms and MT compatibility
Old Jan 28, 2008 | 10:14 PM
chinito's Avatar
Default 2-way remote start alarms and MT compatibility
i am looking at 2-way pager remote start alarm systems. particularly DEI brand. I cannot tell which ones are MT compatible or are they only for AT's? I like the python 1090 and the hornet 564. curiously, the hornet 564 sister, the avital 4400 is only AT, but i think the hornet 564 is MT and AT. any hints here?
Old Jan 28, 2008 | 10:17 PM
mcheng08's Avatar
any DEI will work just make sure you bypass the clutch.
check this out
https://www.scionlife.com/forums/viewtopic.php?t=36795
Old Jan 29, 2008 | 12:02 AM
scioncraze05's Avatar
It can be done, I have done a remote start on my tC and it was not an easy task. Since we have 2 starter wires and 2 ignition wires the other 2 wires need relays in order for them to get 12 volts when the car is being remote started. So you would need 3 relays, 1 for the clutch bypass, 1 for the 2nd ignition wire, and 1 for the 2nd starter wire.
Thats only if you plan on installing this yourself. If you do not, I'm pretty sure your shop will know what to do.
Old Jan 29, 2008 | 12:13 AM
chinito's Avatar
i was really looking for an alarm that is designed for MT. while i am fond of "koreangineering," i prefer ready-to-go MT-compatible system. These do exist, right?
Old Jan 29, 2008 | 12:16 AM
nothing is ready to go for a MT. there is a lot of work in order to get a remote start to work properly on a MT. Any Compustar alarm/remote start will work with a MT car. I highly recommend Compustar because in order for you to remote start a MT car it has to be in a mode called Reservation Mode. If the car is not in that mode then it will not remote start. Once it is put in that mode and any of the doors or hatch is opened it cancels it and will not remote start, so there are safety features for a MT car.
Old Jan 31, 2008 | 04:50 AM
BuckeyeBrad's Avatar
ha this really comes in handy in the winter it is so worth it
Old Jan 31, 2008 | 03:46 PM
Keeshwah's Avatar
DEI has a module designed for manual transmissions. Every other auto-start will work, just be sure your car is in neutral when you use it. Although it might be cool to start the car and jump in it like Batman.
airmankevin1
Feb 14, 2018 01:23 PM
mw1957
Mar 16, 2015 06:00 PM
idriveanxa
Mar 8, 2015 12:03 PM
757_BRDFLY
Jan 9, 2015 12:29 PM
BV19869
Dec 11, 2014 06:05 PM
