jacking up lowered car
Old Jan 30, 2008 | 02:29 AM
ISTCIONI's Avatar
Default jacking up lowered car
hey guys my car is lowered on tein h techs and i have a real hard time jacking up the car...any one know any hydraulic jacks that would work? and where is the point to jack up in the front? thanks
Old Jan 30, 2008 | 02:31 AM
ADRdesignCo's Avatar
there are arrows underneath the door. if you look under the car thats where you lift it. im on htechs too and i have no problem lifting them with the stock scissor lift thing.
Old Jan 30, 2008 | 02:36 AM
ISTCIONI's Avatar
well i wanna jack the front up cause im doin some work to my car..the sides are still good
Old Jan 30, 2008 | 02:39 AM
Higgy's Avatar
jackstands will be your friends. Go to autozone or somewhere and buy a set. It usually has a jack and 2 jackstands.
Old Jan 30, 2008 | 02:40 AM
BZinn1's Avatar
If you get a 2 1/4 ton jack at Sears it fits perfectly under the car........and cost is minimumal.......there are arrows on the side of car that show where to put jack.
put it right on the weld spot where the two notches are........then put jack stand under the frame rail............yes jack stands area must and are cheaper than a jack........and will save your life.......also sold at Sears..........
Old Jan 30, 2008 | 02:45 AM
Aroddalobster's Avatar
i got a low profile jack from pep boys for 100$ and some jack stands. i'm dropped on hotchkis, and it just slides right under.
Old Jan 30, 2008 | 03:14 AM
Shaka_Z's Avatar
there is also a hardpoint (literally looks like a raised bump) right under the front engine mount where you can place a jack to lift the entire front end at once. if you have trouble getting the jack under the car from there, you can always drive it up on a nice long 2x4 to give it a couple inched clearance or just remove the front bumper cover. I have this exact problem lowered with the kaminari front bumper cover.
Old Jan 30, 2008 | 03:16 AM
engifineer's Avatar
Another trick if working on a really low car is to drive the car onto two short peices of 2X8 before jacking it up. To make it better , you can cut a wedge on the ends to make them easier to drive up onto. This will give you another 1.5 inches to work with .
Old Jan 30, 2008 | 03:18 AM
Shaka_Z's Avatar
beat u to it lol ^^
Mightygnu's Avatar
Try being on S-Techs and 17's... its a little difficult!
Old Jan 30, 2008 | 03:19 AM
engifineer's Avatar
Originally Posted by Shaka_Z
beat u to it lol ^^
ha ha.. I was surprised when I didnt see that someone had mentioned it yet :D
Old Jan 30, 2008 | 03:20 AM
MR_LUV's Avatar
Administrator
Administrator
Default For years, I've been using Portable Car Ramps...
Sorry to Intrude.
You don't need a jack or jack stands IF you're Home.
Or take them to a friend's place,
Just Drive on up. No Jacking, no stands, no lowering.
Mine are cupped at the top of the ramp and the wheels sit in them.
Do Recommend you Chock the back wheels.
Better Ramps:
http://www.discountramps.com/low_profile_car_ramp.htm
Less Expensive types:
http://www.nextag.com/car-ramps/search-html
Bought some 20 years ago at Grand Auto for $19.95 pr
MR LUV
Old Jan 30, 2008 | 03:27 AM
the thing about the car ramps, is that my car, and my friend's integra almost seriously ripped off our bumpers when we tried driving up on them. so jack it is for us
Old Jan 30, 2008 | 03:54 AM
MR_LUV's Avatar
Administrator
Administrator
Not Cheap.
But, it's worth it, if you can afford them.
Or split the cost with your buddies.
MR LUV
Old Jan 30, 2008 | 04:05 AM
engifineer's Avatar
Ramps are all good and great until you need to remove the wheels to do anything
Old Jan 30, 2008 | 04:09 AM
Mightygnu's Avatar
hahah. yes sir.
Old Jan 30, 2008 | 04:34 AM
MR_LUV's Avatar
Administrator
Administrator
No Problemo.
Drive up on the ramps.
Have a couple of your strong buddies hold up the front end.
Yank the ramps. Remove the wheels and start working.
MR LUV
Or Hire strong midgets to crawl underneath and push up.
Think Out of the Box :D
Old Jan 30, 2008 | 04:40 AM
Need4Bass05's Avatar
lmao^
Old Jan 30, 2008 | 06:29 AM
andino's Avatar
lol i hear yah on that one
Old Jan 30, 2008 | 06:36 AM
maximthegreat's Avatar
No Problemo.
MR LUV
quote of the day!
