Exhaust Leak?
Old Jan 30, 2008 | 03:19 AM
silvrxb's Avatar
Default Exhaust Leak?
I'm going to install my exhaust myself. How do i check to see if it is leaking after install? I bought a torque wrench/ratchet (whatever) so that i tighten everything correctly.
Old Jan 30, 2008 | 03:28 AM
CIONIDE's Avatar
If you pass out from carbon monoxide while driving, then it is leaking.
Old Jan 30, 2008 | 05:02 AM
Velocitysport31's Avatar
just make sure everything is snug, you will hear the leak if you have one. you really dont need a tork wrench, just a good rachet.
Old Jan 30, 2008 | 05:19 AM
draxcaliber's Avatar
start your car, plug up the exhaust tip, if it stalls out, your exhaust is sealed, if it leaks, it will continue to rum.
Old Feb 2, 2008 | 01:38 PM
chadfo's Avatar
I don't think I'd try this method. That pressure has to go somewhere and back through the engine is not good.
After installing the exhaust start the car and move your hand around the connections. Do this quickly after starting the car so if you accidentally touch the exhaust it will not burn you. If it's leaking you'll feel the gases pushing out and in many cases you'll hear them.
DaBlackBox
134
Apr 10, 2022 02:04 PM
eric29
15
Apr 26, 2016 07:27 PM
Andreas24
May 17, 2015 09:05 AM
PTUNING
Dec 11, 2014 08:09 PM
PTUNING
Dec 6, 2014 03:58 PM
