Pioneer in dash dvd player with nav install....
Old Feb 8, 2008 | 04:17 PM
IntegraR210's Avatar
Default Pioneer in dash dvd player with nav install....
I purchased the Pioneer AVIC-D3 in dash dvd player with nav. I was wondering if anybody else has this unit. It says to hook this unit up to the speed sensor to give accurate readings. Does anybody know which wire is the speed sensor wire. I looked online briefly to see if there was anything threre, no luck. If any body has a wiring diagram, that would be great!!!!
Old Feb 8, 2008 | 04:20 PM
midtowndesi's Avatar
Sorry I can't be more helpful but someone on here installed a Camry navigation unit in their xB going back a few years. they posted instructions and the person tells you which wire is the speed cable.
Take a look in the tech section in might be in there.
fwiw,
- sh00k
Old Feb 8, 2008 | 04:46 PM
bB2NER's Avatar
Music City Scions
If the nav unit works off of GPS, why would it need to be hooked up to a speed sensor?
Old Feb 8, 2008 | 06:28 PM
koalaty2's Avatar
The Vehicle Speed Signal is on a black connector (second in from the drivers side, under glove box, Pin # 17 Violet/White wire. The wire comes out of the connector on the right side, and is easy to locate. This informaton is taken from my cruise control installation instructions. The instructiions state it is a white connector in the installation instruction, but it is black. The violet/white wire is the give away.
Old Feb 8, 2008 | 07:34 PM
LOL - correct me if im wrong, isn't that how gps works? some GPS' show you the speed your going, calculate the time you're going to get there and these are things that all rely on vehicle speed.... this is why you gotta use the connector.
i also know that gps software calculates ur speed based on where u were the last time the satellite was queried vs where you are now.......... im guess though but that's as much as i know. maybe it's a use of both? i duno
another thing - some units won't play dvds if the car is moviing so that's another reason they attach it to a vehicle speed sensor wire..
Old Feb 8, 2008 | 08:09 PM
bB2NER's Avatar
Music City Scions
Then why do the GPS widshield units that plug into the cig lighter work without the connection to the speed sensor?
If the wire connection is only there to keep you from playing DVDs while in motion then just leave it disconected.
Old Feb 8, 2008 | 08:14 PM
equinox2355's Avatar
Its quite simple.. its ment for more ACCURATE estimates of time, and also when going up or down a hill it cen get accurate speeds, and when going through tunnels in which you dont have any GPS signal.
The ones that mount on the dash guess most of the time.
Old Feb 9, 2008 | 02:11 AM
houseofgrafx's Avatar
the Pioneer AVIC-D3 is not a GPS navigation system. It uses a navigation disc, therefore it needs your speed sensor to tell the navigation software where you are
Old Feb 9, 2008 | 03:25 AM
bB2NER's Avatar
Music City Scions
Oh, OK I'm being schooled in this stuff right now. Thanks!
Old Feb 9, 2008 | 03:27 AM
thanks, Im going to install tommorrow. Yes I know its a disc Navigation, thats why it needs the speed sensor hookup. The "safety device" that keeps the DVD player from not working works off the parking brake hookup. Thanks for the tips. Ill let you know how it went....
Old Feb 10, 2008 | 11:27 AM
techniguy's Avatar
ok does everyone know that you have to just take off the a/c ***** and pop the middle center piece to install a stereo? because I had no idea when I installed my double din.
BlingSlade
Oct 19, 2016 12:39 AM
prescottn
Scion tC 2G ICE & Interior
Apr 26, 2016 01:14 AM
prescottn
Oct 8, 2015 05:31 PM
OpTicaL
Sep 16, 2015 10:25 AM
dyenfd
Sep 13, 2015 10:00 PM
