eibach sportlines
Old Feb 10, 2008 | 10:58 PM
chrisdiablo's Avatar
Default eibach sportlines
Hello everyone got my car lowered with eibach sportlines 2.0 inch front and back, with an alignment. I am new to lowering a vehicle but after reading everything about what is involved decided to do it. My question is what are your personal opinions on how long or not so long the suspension parts will last, shocks, struts, etc. Should I be worried? I also looked throughout the suspension forums and read countless opinions but just wanted to "refresh" this topic. Thanks for your comments.
Old Feb 11, 2008 | 03:42 AM
01msmis's Avatar
did you get new shocks with it? or just springs? It really depends on how you drive. if u go crazy with ur suspension then it wont last as long.
Old Feb 11, 2008 | 03:50 AM
Just springs.
Old Feb 11, 2008 | 04:38 AM
Super-Stormtrooper07's Avatar
I had Eibach sportlines on my old Honda, and really didn't like the ride quality of the spring. They get all coiled up, with very-very little spring still left in them, which affects the strut/shock life - and makes them work harder/ more stress.
All for an extra .25 to 1/2" further drop, personally IMO its not worth it.
Thats why this time I went Eibach Pros. Tein can make some good stuff, there are a bunch of Tanabe lovers here... which could be good , and not much bad to say about the TRD springs- other then its just a 1" drop(not sure if thats enough for you/most people).
I suspect if you want to go 1.8" or more drop(which a camber kit is then needed) , optimally its best to go with Coil-overs = but then your looking at about $800 minimum , on up$
Old Feb 11, 2008 | 04:59 AM
breaux_tC's Avatar
you're sure about that... ?
Old Feb 11, 2008 | 05:01 AM
No camber kit required.
Old Feb 11, 2008 | 05:03 AM
breaux_tC's Avatar
yeah.. i thought it was after 2" or so
Old Feb 11, 2008 | 12:19 PM
digndoug's Avatar
WITH THE SPORTLINES, YOU WILL WANT NEW SHOCKS. STOCK ONES WILL LAST YOU MAYBE 10K BEFORE THEY START TO GIVE.
YOU WILL NEED A CAMBER KIT, IT MAY NOT LOOK LIKE MUCH, BUT I HAVE HAD THREE CARS ON SPORTLINES, THE FIRST AFTER DRIVING 10K WITHOUT A CAMBER KIT, I NEEDED NEW WHEELS.
I WENT WITH THE KONI YELLOWS WITH MY SPORTLINES, AS I DID EVERYTHING AT ONE TIME, I ALSO DID HOTCHKIS SWAY BARS AND THE HOTCHKIS REAR ALIGNMENT BAR AND EIBACH FRONT ALIGNMENT KIT, AN DC FRONT STRUT TOWER.
SORRY FOR CAPS, AT WORK.. LOL
Old Feb 11, 2008 | 03:00 PM
breaux_tC's Avatar
im about to install the hotchkis springs
any words of wisdom on that?
Old Feb 12, 2008 | 04:38 PM
Right.
I always thought Sportllines were 2" on the front... maybe 1.8" on the rear. Thus, to do it right , and make sure your tires do not wear funny, get a FRONT camber kit = more money your throwing at the fire.
I remember when I had my sportlines on my honda, the tires after about 7-8K miles were reallly starting to wear funny/ bad, which to make a long story short was one of the weak links in puting that car 6 feet under/dead.
Old Feb 12, 2008 | 06:43 PM
digndoug's Avatar
Right.
A Camber kit will fix the camer on a wheel. When you lower the car, you get a negitive camber, good for a race car bad for a daily driver, because the inside of the wheel will ware faster then the outside. You get a camber kit, you can adjust postivie or negitive. Sence my 2" springs gave me a negative camber, i needed to adjust to make it even.
Old Feb 12, 2008 | 07:05 PM
I totally concur on gettting the camber kit if you go Sportlines ... anything right at 2" or more. Its just a needed / extra part, more money invested into your whole suspention set up is all.
Old Feb 13, 2008 | 02:30 AM
tc913's Avatar
I have the eibach sportlines and I don't have a camber kit in the rear. They got it back within specs pretty well. I haven't really seen any major tire wear issues so I don't think it's necessary unless it gives you the piece of mind then get it but usually you don't need it unless you are slammed.
Chimmy3
91
Nov 20, 2022 04:35 PM
prescottn
Feb 24, 2016 11:57 PM
scionhawaii
Sep 1, 2015 08:14 PM
carltc14
Apr 21, 2015 10:51 PM
rcruz2525
31
Apr 8, 2005 11:37 PM
