2004-2006.5 [NCP61]
Air Filter Change prompts service engine light?
Old Feb 15, 2008 | 11:16 PM
cobb's Avatar
Default Air Filter Change prompts service engine light?
I changed my oil today and after wrestling with the air filter, declided I just as well replace it. I had to unplug the sensor, unplug a few hoses since I have a strut brace blocking it to swap the filter. I started the car up, no leaks everything sounded ok and drove off. Saw my service engine light was on.
Anyway, It seems to run fine, I used my scan guage to clear the codes before I thought about writing them down.
Any idea if unplugging the air flow sensor can case that problem?
Old Feb 16, 2008 | 05:16 PM
jct's Avatar
jct
no it should not cause the problem
are you still using the stock airbox with the paper filter?
Old Feb 16, 2008 | 06:43 PM
SHIFT_xA's Avatar
Team XcelsiA
If you had the key in and in the on position, or if the car was running and the sensor was out, YES that can cause a check engine light.
Old Feb 16, 2008 | 08:46 PM
cobb's Avatar
I had the key in, but it was not running. I replaced the stock toyota denso filter with a purlator replacement unit. Looked free flowing, fabric vs paper like the stock one. So far no check engine light since I cleared the codes.
Old Feb 16, 2008 | 09:19 PM
pioneer1976's Avatar
if you had the key in the on position then yes that could be why it came on... best to leave key out of ignition when disconecting stuff
Old Feb 17, 2008 | 12:17 AM
SHIFT_xA's Avatar
Team XcelsiA
well hopefully the code doesn't come back!
Old Feb 18, 2008 | 08:17 AM
bB2NER's Avatar
Music City Scions
If you are keeping the stock box you should have invested in a K&N.
Old Feb 18, 2008 | 08:39 AM
1AZ's Avatar
1AZ
are you sure it wasnt your light for oil ! cuz after that maintnce light comes on you have to erase it or it will stay on! happen to me after oil change had to read the manuall on how to erase it!
my 2 cents
Old Feb 18, 2008 | 09:43 PM
cobb's Avatar
It was the engine logo, not the engine needs service soon light. I change my oil between the dealer changes so its like changed at every 2500 miles..
So far has not come on. I was going to get a cold air, warm air, reusable filter, but I hear mixed results regarding fuel economy I just stick to the stock one. Infact I find removal of the snorkle lowers my fuel economy.
Miqmiqmiq
Apr 16, 2016 02:34 AM
daniinpitt
Apr 4, 2015 08:07 PM
cid_mcdp
Jan 5, 2015 02:45 PM
Godfryness
Jan 2, 2015 11:18 PM
hotroddelux
Dec 3, 2014 11:33 PM
