Need help fuse box
Old Feb 21, 2008 | 05:59 AM
Hyung's Avatar
Default Need help fuse box
i think i blew a fuse. the mode and ac ***** wont turn on lights i was messing with the dimmer wiring for a cathode kit and sum idiot triped over the wiring
which fuse?
Old Feb 21, 2008 | 05:32 PM
bigpapa's Avatar
I don't have a fuse location for you, but if I were in your shoes I would grab a multimeter, set it to continuity (usually will have a speaker icon on the dial) and touch both probes to the top of each fuse. Each good fuse should give you an audible tone. When you get to a bad fuse there will be no tone. No need to remove the fuses.....just go down each column and start probing. The fuse you blew is proabably in the dash fusebox, not the engine compartment fusebox. Doing it this way should take you no more than 5 minutes.
Old Nov 3, 2008 | 09:13 PM
xbgrl's Avatar
I know this is from a long time ago but, I would just like to know if this problem was ever solved, because i am having the same thing happen to me yet the strange thing is all of my fuses work. Are there any other fuses I should know about?
Old Nov 7, 2008 | 03:51 PM
xbgrl's Avatar
anyone????? I guess not. Is there more than one fusebox other than the one under the dash by the door on the drivers side??
Old Nov 7, 2008 | 05:37 PM
rockthebeef's Avatar
Yup. There's also a fuse box under the hood. It's covered with a lid and it's right next to the Air filter box.
Old Nov 7, 2008 | 06:09 PM
CIONIDE's Avatar
Pages 264 & 265 of the 2008 xB Owner's Manual outlines the location and function of every single fuse on the car.
None of them are itemized specifically as temperature control **** lights, but it will give you a big head start as to which fuses to look at.
Old Nov 7, 2008 | 08:35 PM
xbgrl's Avatar
Hi thanks for your responses . I took a look at the fusebox under the hood and tested every fuse. They work fine, so now im under the assumption that perhaps something is wrong with t he dimmer fuse? Ill have a look at the manual too(something i should have done anyway) thanks again!
Old Nov 7, 2008 | 08:55 PM
CIONIDE's Avatar
You're welcome; here to help.
Old Nov 7, 2008 | 10:25 PM
xbgrl's Avatar
ugh looks like im gonna have to bite the bullet and go to the service dept cause im stumped.
Old Nov 7, 2008 | 10:35 PM
CIONIDE's Avatar
At least it should be covered by warranty... unless YOU did something that caused it.
Old Dec 21, 2008 | 10:32 PM
xbgrl's Avatar
Well, I figured out the issue and did another double check on the fuse and turns out it was the "panel" 7.5 fuse that was blown.
Old Dec 21, 2008 | 10:35 PM
CIONIDE's Avatar
Glad you figured it out and got it fixed.
Old Dec 31, 2008 | 07:28 PM
Cactusc00ler's Avatar
Where exactly is that fuse?
elwaylite
9
May 15, 2020 07:27 PM
Jumphiggggg
Scion tC 1G ICE & Interior
Jul 15, 2015 02:29 AM
SoCal_CJ
Jul 14, 2015 09:14 PM
excessads
Jul 13, 2015 11:41 AM
