SUSPENSION COILOVER QUESTION, URGENT!!!
Old Feb 27, 2008 | 01:58 AM
JamesTC_Silver's Avatar
Default SUSPENSION COILOVER QUESTION, URGENT!!!
i just took off my rear stock shock to replace it with my H&R coilovers, do i take every upper mount piece off of the stock shock and put it on the new one? we cannot get it on and its making me angry so any help ASAP will be awesome!
Old Feb 27, 2008 | 03:55 AM
tCeeder's Avatar
i don't have coilovers but i think if you are putting them in you must transfer the old mounts and stuff onto the new coilovers (unless your coilovers came with new mounts).
please correct me if i'm wrong.
Old Feb 27, 2008 | 05:02 AM
Joe_Dezod's Avatar
Yes.
I had the H&R coilovers on our company car and it uses the stock hats. You need to remove the stock tops on all four corners and reuse them on top of the H&R coilovers. H&R provides replacement nuts for the top of the new shock.
Let me know if you have any other questions. Thank you.
Old Feb 29, 2008 | 06:02 AM
we have to take them into a tire shop to have them compress the shock down so we can put the upper mounts on, our shock compressor was too big but oh well i will get them on soon
Old Feb 29, 2008 | 06:57 PM
Joe_Dezod's Avatar
Compressor?
I did them in my garage by hand... Are your sure you and a buddy cant just push down a little to thread the nut on? It's been a while so I don't remember how tight it was. It should be straight forward though...
Old Mar 1, 2008 | 05:33 PM
yeah we could not do it, they were really stiff, but i will have them done on monday so i will post pics in the lowered cars section
Old Mar 2, 2008 | 03:48 PM
davedavetC's Avatar
lower the coilovers all the way, that will give you enough room to thread the nut, then once yuou get it on the car the weight of the car will allow yuou to thread the nut tight. thats what i did with my rears
also on the fronts make sure the spring hat moved freely, if it doesnt you will get a really annoying popping sound when driving.
Old Mar 2, 2008 | 06:40 PM
yes they are finally on, thanks davedave we did that and it worked, duhhhhh i couldnt believe i did not try that before, but how do you lower the fronts, do you raise the rings or lower the rings, cause the rear you have to raise the rings in order to lower, is that the same as the front coilovers??
Old Mar 3, 2008 | 02:27 AM
davedavetC's Avatar
the rings should be the same for the front, if you want a lower drop you bring the rings down
i havent adjusted the rear in a looong time but the fronts i know to drop it you bring the ring down
Old Mar 3, 2008 | 05:36 AM
alright cool thanks
bootlgr
Jan 26, 2016 01:22 AM
Greg S
May 28, 2015 12:46 AM
TotalChaos
13
Feb 4, 2015 10:24 PM
STCxB
11
Jan 9, 2015 04:30 PM
fearturtle44
15
Feb 13, 2004 01:15 AM
