RUBBING QUESTION
Old Mar 1, 2008 | 05:46 AM
scionora09's Avatar
Default RUBBING QUESTION
Okay. . .so this is what I am trying to understand. . . .
1. What exactly are the negative effects of rubbing? And what part of the wheel actually rubs?
2. If you are aware of these negative effects, why do you still lower your car such that it rubs?
3. Besides fender rolling and cutting out plastic how do you minimize or eliminate rubbing if at all possible?
I ask this because I am fighting myself over what wheels to get, but all the rims that I want to get are 19x8.5. . .and I want to lower my car without rubbing. . .but TRD is not quite low enough for me. . .however id rather get TRD's if it means I don't rub. . .is there ANY way around this?!
Old Mar 1, 2008 | 05:49 AM
boostedbox06's Avatar
you may have to roll your fenders...
Old Mar 1, 2008 | 06:50 AM
nebster's Avatar
Default Re: RUBBING QUESTION
1. depends on where its rubbing, it can rub the fender, the plastic liner, the inner fenderwheel (lock to lock) it really depends on your wheels. Negative effects are extreme wear on your tire / plastic to the point where its decentigrated.
2. it looks bad ___
3. change wheels?
the only way is to remove plastic, roll fenders get different wheels or select a different drop..... do it or don't do it lol it doesn't both me but my plastic liners are completely shot
Old Mar 1, 2008 | 03:13 PM
dex's Avatar
dex
get the right size wheel and offset then you dont have to worry about rubbing. a 18x8 wheel with a +35-40mm offset will look good without worrying about rubbing. unless your into this look...then forget everything i said.
Old Mar 3, 2008 | 07:20 PM
scionora09's Avatar
do coilovers eliminate rubbing regardless of how low you go? If so why?
bootlgr
Jan 26, 2016 01:22 AM
Greg S
May 28, 2015 12:46 AM
Scionxa180
Mar 13, 2015 04:39 AM
TotalChaos
13
Feb 4, 2015 10:24 PM
fearturtle44
15
Feb 13, 2004 01:15 AM
