JL Audio 10in. W7
Old Nov 17, 2004 | 09:00 AM
Male_Nurse's Avatar
Default JL Audio 10in. W7
I just recently purchased the W7 and I want to hear other people's impression on this sub. Was it worth the purchase? Quality level? Longevity? How good is the bass? Also, I'm wondering if anyone can help with getting the right box (sealed or enclosed) and what kind of amp can i buy that's much cheaper than the JL amp but can match the RMS (500w)
Old Nov 17, 2004 | 09:35 AM
hotbox05's Avatar
wrong area. needs to be in ice. and yeah nice sub but it will need alot i mean alot of power. and a box with exactly the suggested airspace. it bumbs but too much money for most.
Old Nov 17, 2004 | 11:34 AM
Soon2HaveAbox's Avatar
I had a JL 12W7 and loved it. Personally I think it is one of the best subs available.
As far as building the box, go to the JL Audio website and build it to the specs they recommend. I did exactly what they had on their site when I had mine and it sounded great.
Old Nov 17, 2004 | 04:08 PM
VtScionGuy's Avatar
Great sub and let NO ONE tell you otherwise. Lots of people just hating on the W7 cuz they can't afford it. I had two tens and they were well worth the money. If you don't know much about box design and bracing then get a dealer to build a box for you, about $125. The baffle is uses two pieces of MDF instead of one.
What kinda budget for an amp?
Old Nov 17, 2004 | 05:31 PM
Male_Nurse's Avatar
"what kind of budget for an amp?"
- Probably around 300-400 range? Any suggestions?
Old Nov 17, 2004 | 06:08 PM
to run the 10w7, a JL Audio 500/1 will work fine. and you can get them new or used on ebay for between $300-$400. I used the 500/1 on my 12W7 and everyone said it was underpowered, but it sounded amazing. IMO a 500/1 is what I would go with.
Old Nov 17, 2004 | 08:04 PM
Minsk99's Avatar
Yup. JL recommends the 500/1 for this sub. Also below is a cut and past of recommended enclosure dimensions from the JL web site. You should definitely checkout the pdf they have on the 10W7.
Dimensions:
Frame Diameter: 10.5 in. (267 mm)
Mounting Hole Diameter: 8.74 in. (222 mm)
Mounting Depth: 8 in. (203 mm)
Overall Depth: 9.63 in. (245 mm)
Magnet Diameter: 6.55 in. (166 mm)
Pole Vent Clearance: 0.75 in. (19 mm)
Displacement: 0.09 cu. ft. (1.78 ltrs)
Enclosure Recommendations:
Sealed Range: 1.00 - 1.375 cu. ft. (28.3 - 38.9 ltrs)
Recommended Sealed Volume: 1.25 cu. ft. (35.4 ltrs.)
Fc: 44.7 Hz
F3: 40.7 Hz
Qtc: 0.785
Ported Range: 1.125 - 1.5 cu. ft. (31.9 - 42.5 ltrs)
Recommended Ported Volume: 1.5 cu. ft. (42.5 ltrs)
Recommended Tuning: 32 Hz
Port Type: “Slot” ports are recommended. See Data Sheet for detailed info
Old Nov 18, 2004 | 11:36 AM
Dimensions:
Fc: 44.7 Hz
F3: 40.7 Hz
Qtc: 0.785
Definately look at the pdf file. They give you the actual sizes to build the bow and everything.
Old Nov 18, 2004 | 08:31 PM
JLTD's Avatar
If you do not want to spend for the 500/1, you could use the 250/1 or the e1400D. Do yourself a favor and not buy JL products off the internet.
If you already saved up for the Porsche, keep her filled with the Premium gas.
Just so you know......there's no such thing as "under-powering" speakers. Any amp JL Audio offers will be compatible with a 10W7 except perhaps a 1000/1. The e1800D would also work, but it's the same price as a 500/1.
Feel free to PM me with any questions you have about JL Audio.
Old Nov 19, 2004 | 01:18 AM
mgmlot93's Avatar
I have a 10w7 in my Xb. It is in a 1 cubic foot box and powered by a JL 500/1. I can honestly say this is the best sounding single subwoofer I have ever heard. I have owned many, many subwoofers and amplifiers and this setup has truly impressed me. You will love it.
Old Nov 19, 2004 | 04:53 AM
Swifty808's Avatar
Jl W7 nothing will beat it my friend got 2 in his corolla type S and running it on two 1000 watt Phoenix gold amps.. hes a lucky ___ and works at a sound audio shop as the guy who takes calls!!! tho he can set off car alarms with jus his sounds about 50 feet away
Old Nov 19, 2004 | 07:05 AM
usdmbB's Avatar
Please dont use any other amp than a 500/1 or a 250/1
I would use the single ported box that comes in the owners manual.
I have used this box many times and it will rock you PERIOD. The 500/1
on this will really do the job and you will be very glad you did.
Old Nov 19, 2004 | 08:35 AM
Male_Nurse's Avatar
any where you guys think i can get a hook up on the 500/1? I've pretty much looked at different amps that can power my sub but as far as i know the 500/1 is the best amp to compliment my sick ___ sub.
Old Nov 19, 2004 | 08:55 AM
propolis's Avatar
N.G.S.O.
i had a w7 hooked to my memphis bell amp and it "pushed out" the back window to my old jeep, not broke or cracked, pushed, as a whole piece of glass. it was an old crappy jeep but the sub sounded incredible, i still have it and plan on putting that system in my tc
Old Nov 19, 2004 | 09:01 AM
Male_Nurse's Avatar
Damn, all this talk about the W7 and the 500/1 being the best combo. I won't be getting the sub working in my car for awhile because of my accident. I recently got into an accident about 2 weeks ago. I got T-BONED. The car's at the shop getting fixed and it'll take about 4 weeks before i get that thing back. My back started to hurt right after that accident so i've been going to the chiropractor since then.
carid
Aug 7, 2015 11:32 AM
marsman328
Regional - Pacific Mid
Jul 28, 2015 09:43 PM
Beesh
Jan 9, 2015 06:30 PM
