TYC replacement bulbs
Old Mar 7, 2008 | 03:29 PM
mercedes's Avatar
does anyone know if the bulbs for the TYC lights on the TC can be replaced? i want to try to get LED reverse lights, but i dont know what size the bulbs are. the stock ones are 921. are the TYC's the same?
bump
Old Mar 7, 2008 | 10:20 PM
Parfnut's Avatar
Yes!! The reverse bulb in TYC's are the same as stock tails (921's). I have LED 921's in my TYC's.
Old Mar 10, 2008 | 02:30 PM
mercedes's Avatar
sweeeet. got any pics of them?
Old Mar 10, 2008 | 09:31 PM
Parfnut's Avatar
Not sure why picture of back up light turned out blue. They are actually more white with a hint of purple. Maybe I'll try a shot from further away or fiddle with camera settings! Don't expect the light output to be better than the stock bulb. This is a 9 LED bulb which I plan to upgrade to a 18 LED SMT(a little pricey) 921 bulb shortly.
Old Jul 26, 2009 | 10:50 PM
GrnBrownies's Avatar
Bump. I recently got some TYC lights and I see the reverse lights are 921's. Does anyone know what bulb fits into the turn signals?
Old Jul 27, 2009 | 05:16 AM
cweckel2000's Avatar
The turn signals are 7440's. Just an FYI I just converted my turn signals to LEDs and you are going to want to spend the $ up front to be happy. I went through 2 differnt types of bulbs before I found these. Most LED's are NOT bright enough for turn signals to be easily visible during the day time. Yeah these arn't cheap but they are as bright if not brighter than the stock bulbs.
http://autolumination.com/7443_7440.htm
Also, you will need to buy load resistors if you want the signal to blink at the same rate that is does with the regular bulbs.
Old Jul 27, 2009 | 11:47 AM
Thanks I'll definitely take up on your advice
Old Dec 14, 2009 | 04:25 PM
alenehan's Avatar
anyone know what LEDs are in tycs? I need to replace a few
Old Dec 14, 2009 | 05:38 PM
SquallLHeart's Avatar
you can't replace the leds in the TYCs...
that is.. without cutting the entire thing open
Old Dec 16, 2009 | 07:36 PM
Sciontistical_One's Avatar
Originally Posted by cweckel2000
...Also, you will need to buy load resistors if you want the signal to blink at the same rate that is does with the regular bulbs.
Any idea/info on what type of resistors are needed?
Old Jan 19, 2010 | 07:45 AM
alenehan's Avatar
well if i were to open them up.... i would like all the LEDS working, so again, anyone know what kinda LEDs i need?
Old Jan 19, 2010 | 12:47 PM
i'm not sure but as a last resort, u can buy a pair of damaged TYC's.
here's a pair i found. was posted back in december, but if you're interested, contact him and maybe you can work out a deal.
https://www.scionlife.com/forums/showthread.php?t=177048&highlight=tyc
Old Jul 12, 2015 | 01:39 AM
alxm's Avatar
Moderator
Moderator
Thumbs up Philips 7440 Red Led
7440 7443 wy21w led bulb tail turn signal parking brake backup lights
Sorry to revive but just in case anyone out there is still looking for a true 7440 led bulb. As many sold are actually 7443 but sold as 7440 or 7440 compatible. And are not that bright. I stumbled across these at my local Pep Boys. They are Philips Vision 7440 red led's, link below.
VisionLED LED car lamp 12838B2 | Philips
They are marketed as stop and tail led's. But I use them as rear turn signals in my aftermarket tails. Yes they still do need the load resistors or upgraded flasher relay to correct the fast flash. But they are brighter than my previous 7443 compatible led's that I just was never satisfied with. I went through about 5 different styles with different multiples of led's in the actual bulb, red and white color(the turn signal lens is red) and they just were never bright enough. The last pair I bought before these were advertised as true 7440 and the pic looked like 7440's. But what I got, again, were 7443 compatible led's.
So while waiting for a repair on my other car at Pep Boys. I saw these Philips and was happy to see they were true 7440s and decided to give them a shot. They are around $30 on average for the pair. Have a 12 year warranty and they are solidly built. What's interesting about them is that they don't have top mounted led's. The led's are mounted at angle to aim back towards the reflector in the housing. They are still bright on their own but this design results in a brighter output when installed in housings with a reflector.
So if anyone is looking for red 7440 led's. Try and give these a shot. I've also included an Amazon link below for them that has some reviews.
Amazon.com: Philips 12838REDB2 Red Exterior Vision LED Bulb (Pack of 2): Automotive Amazon.com: Philips 12838REDB2 Red Exterior Vision LED Bulb (Pack of 2): Automotive
P.S. Happy to say too my '05 tC is still running well at 178,000 miles. Had to replace the water pump a couple months ago because of a small leak. But that is fine in my book. Peace.
tato63
Scion tC 2G Wheel & Tire
9
Sep 30, 2015 09:55 PM
blh72
Scion xD Wheel & Tire
Feb 2, 2015 12:36 AM
torranosaurus
Jan 28, 2015 04:53 AM
scsteven
Jan 25, 2015 01:06 AM
jaspercanda
Dec 28, 2014 10:09 AM
