Better interior lighting?
You'll have to forgive me, I'm used to a gas-guzzling Tahoe with enough lights inside to blind Ray Charles.
At any rate, I'm picking up my cube on the 31st and was wondering if there's a way to add better lighting to the interior. I had the demo out last night, and with the interior lights on, it was fairly dim inside. The stock dome was okay, but not bright enough for me.
So, has anyone added better lighting to their box? IE Floor, more domes, etc?
Hey zTagged,
I suggest going to www.oznium.com. Check out their 16 LED Dome Light. It is a tight fit, but it is unbelievably bright. Also, you can pick up a set of LED 194 replacement bulbs. Those will replace your map lights. Lastly, you can get an LED replacement bulb for the rear cargo light and you are pretty much set.
If you want to go further, you can also pick up a some cold cathode tubes for under the dash and seats. Oznium sells those too. They do require some know how for the install. However, if you want a fantastic plug and play cold cathode kit, check out
www.randode.com
Congrats on your new xB!
www.randode.com
Originally Posted by FlyinLow
Hey zTagged,
www.randode.com
www.randode.com
Re: Better interior lighting?
Originally Posted by SheenaPie
here is frozone's thread, watch his videos then go to superbrightleds.com for the map lights...
https://www.scionlife.com/forums/vie...768&highlight=
I bought these at first..
I wasn't too happy with it so I went with oznium. 16 led superflux
I went with 25 led for the dome but I had problems (they replaced with no issues)
pictures with some leds out..
These are bright! the blue ones are almost blinding!
clickclickw00t
02-18-2015 08:57 PM
sithscripter
9
09-26-2003 05:27 AM
