Squeaky Belot on S/C
Old Mar 19, 2008 | 10:22 PM
datboiant's Avatar
Default Squeaky Belot on S/C
Today I noticed that my supercharger's belt was making a high pitch squeaking noise. Would I just need to replace the belt to fix the problem or is it a precursor to a bigger problem? Any help would be appreciated.
Old Mar 20, 2008 | 12:19 AM
BuddhasTC's Avatar
yeah, it's probably just the belt, get a new one and u should be good
Old Mar 20, 2008 | 12:52 AM
datboiant's Avatar
Oh ok thats good to here. Do you think that it will be ok if I ran the belt as it for like another 2 weeks because thats when my new pulley will arrive and I can just change the belt then.
Old Mar 20, 2008 | 03:03 AM
kikcaffine's Avatar
yeah you should be fine. I have shredded off an entire row and it still works fine.
Old Mar 20, 2008 | 03:06 AM
datboiant's Avatar
Alright sounds good thanks for the help
Old Mar 20, 2008 | 03:12 AM
imsonofagun's Avatar
Make sure that the belt is aligned properly on all the pulleys. The belt was squealing on my car and eventually popped off. Luckily it happened in my driveway. The pulley was off-center on one of the idler pulleys. I had a friend at the dealership change a couple pulleys and change the shim to the s/c pulley which got the belt aligned properly.
Old Mar 20, 2008 | 03:14 AM
datboiant's Avatar
Is there a way to tell if its not aligned properly? The noise just started today.
Old Mar 20, 2008 | 03:29 AM
If the belt isn't in the middle of the pulley, then it can cause squeaking. About a quarter of the belt was hanging off the edge of one of the idler pulleys, causing a really bad squeak and sending shreds all over the engine compartment.
Old Mar 20, 2008 | 04:53 PM
gwtc's Avatar
I've noticed that the belt hangs off a bit on one of the idler pulleys, I'm going to have to take it in to the dealer and have them check it out, I've noticed a little bit of shreds around that are, thanks for the info.
Old Mar 21, 2008 | 04:07 AM
GammaTNT's Avatar
Happen to me last NOV, one of my idle plulley was bad. I got a idle pulley, and the tc runs great .
Old Mar 21, 2008 | 04:09 AM
datboiant's Avatar
I'm going to take my supercharger to the dealer tomm to have it checked out. It should be covered under warranty, correct?
Old Mar 21, 2008 | 04:56 AM
GammaTNT's Avatar
yes,
but unfortunately for me, i have 9.5 pulley installed and i was 200 miles from home. A nearby performance shop found out why the belt keep slipping off. and install the idel pulley for me.
Old Mar 21, 2008 | 04:58 AM
datboiant's Avatar
Ah, I see. I hope they will still fix mine since I have a supercharger. How much did it cost for you to install your idel pulley at the shop?
Old Mar 21, 2008 | 04:53 PM
BLUEMEANIE's Avatar
Team Hamster
the dealer will re-shim the pulleys for you for free. There is a section about doing it correctly in the install instructions. If they refuse point it out to them and tell them they didn't do it right in the first place. ...thats what I did.
That said, ever since I stepped up to the 9.5lb pulley I've had a loud very quick squeak at first start up then it's fine. Belt dressing will usually take care of issues like that.
k1114
43
Mar 1, 2023 03:08 AM
ColonelSanders85
Dec 9, 2020 09:44 AM
Greg S
Jul 21, 2016 07:28 PM
Kanchi
Jun 29, 2015 02:42 AM
rshissler
Mar 24, 2015 10:46 PM
