VSS wire location?
Old Mar 23, 2008 | 08:42 PM
jBoRiCuA's Avatar
Default VSS wire location?
I have the Pioneer AVIC Z2 but I'm trying to find that speed wire in the tC to hook it up to the pink/white wire on the Z2.. this one here:
http://yuphost.com/images/IMG_2412.JPG
I saw the wiring diamgrams but none are for the 2008.. and I couldn't even find the wire by looking at the 07 diagram.
Old Mar 23, 2008 | 08:59 PM
shizzzon's Avatar
ok, i hope this helps-
this is for 2006-
It is a purple wire coming off of the ECM which is behind the glove box.
2nd plug from the top.
Also, it is on the radio harness, which is a yellow wire.
Old Mar 23, 2008 | 10:36 PM
mattieg's Avatar
for the 2008 you can only get it at the ecm behind the glove box like shizzon said. If you have a digital multimeter you can set it to AC voltage and have someone read it off to you as you accelerate. The voltage should increase with speed.
Old Mar 24, 2008 | 12:15 AM
SquallLHeart's Avatar
the 2008 diagram pretty much matches with the '07's...
just grab the yellow wire that's right there in one of the stock radio harnesses. (the one that also has the steering control and aux wires.)
Old Mar 24, 2008 | 02:08 AM
mattieg's Avatar
Nice... I did not know that SquallLHeart. jBoRiCuA just make sure you test the wire before you go ahead and tag it.
Old Mar 24, 2008 | 05:54 AM
for the '06+ vehicles... that wire is used as an input into the stock radio for the ASL function..
that's why it's there.
Old Oct 25, 2008 | 01:24 PM
waterhurley's Avatar
im doing a z2 install and its all hooked up except that damn VSS wire. ive her so many different pots on where to get it. my glovebox is out and h have the wire taped to my ECM untill its done
i have an 08 tC. im gonna say 2nd plug from top purple? i need a new meter grrrrr
and since i believe in hard soildering over t-taps, id like to only have to do this once
SkillFreeJake
Scion tC 2G Aero & Exterior
Jul 27, 2015 12:34 AM
KILLER
Mar 29, 2015 05:32 PM
Sagara09
Feb 28, 2015 06:58 AM
randode
44
Jun 29, 2004 04:19 PM
bettysman
Feb 8, 2004 04:50 PM
