Fuel Pump will not turn on!
Old Mar 24, 2008 | 11:58 PM
hustler900's Avatar
Default Fuel Pump will not turn on!
I recently got a totaled 07 scion tc that was hit in the front and flipped onto its side. None of the airbags went off. It has 17,000 miles and the engine and wiring appear to have taken no damage. There was some standing water in the ditch where the car was sitting on its passenger side, but not more than a foot or so deep. When I first tried to start the car, I was getting no spark. I noticed that the ignition fuse was blown so I replaced it thinking that it would now start right up. Still just turns over, but I believe that the fuel pump is not coming on at all. I removed the back seat and the fuel pump cover and can not hear the pump making any noise when the key is turned to the on position or when cranking the engine over. Does anyone have any idea why this could be? I believe that I am getting power to the EFI relay. Which fuse is used for the fuel pump circuit? Thanks for any help.
Old Mar 25, 2008 | 03:39 AM
dos_techie's Avatar
Smack it with a hammer or check the realy...
Old Mar 25, 2008 | 04:46 PM
jimmyjun's Avatar
check the relay and all the fuses(engine bay & inside the car). i would actually check first the efi fuse(#20 on top of fuse)and the ecu fuse, both in the engine bay.
Old Mar 27, 2008 | 06:11 PM
3min3m2's Avatar
could also be a bad pump b/c of the wreck, good luck
Old Mar 27, 2008 | 11:12 PM
hustler900's Avatar
Looks like the electronic control module above the glove box got wet. There is some corrosion on the connectors when I took them off. I will open up the ecm later to see if any moisture got inside.
Old Mar 27, 2008 | 11:14 PM
dannygenio's Avatar
put in neutral and try again....
Old Mar 28, 2008 | 01:28 AM
hustler900's Avatar
looks like it was the electronic control module. It got wet from water in the ditch and got all corroded inside while it sat at the tow yard. anybody have an edm from an 07 tc auto trans that they would like to sell?
Old Mar 28, 2008 | 04:26 PM
3min3m2's Avatar
check junk yards, hard to tell if anyone has one
Old Nov 20, 2023 | 11:05 PM
Freeatlastyeah's Avatar
where the hell is the relay for the fuel pump?
anti_virus347
Apr 3, 2015 05:17 PM
GetSlideways
Scion xD Drivetrain & Power
Mar 16, 2015 11:30 PM
whiteboymills
Mar 14, 2015 08:10 PM
cid_mcdp
Jan 5, 2015 02:45 PM
dgm458
Dec 7, 2014 05:59 PM
