spoiler problem..
Old Apr 5, 2008 | 04:00 AM
demzzy's Avatar
Default spoiler problem..
ok here's the thing.... i bought my spoiler it came... factory oem.. now.. from what im seeing in the instruction... i have to use the connector that was on the stop lamp ... but thing is... my xa DOESNT havent have anything back there... would i hve to run fresh wire for the break led to work?
Old Apr 5, 2008 | 07:36 AM
scion_jon's Avatar
what?
Old Apr 5, 2008 | 10:24 AM
Pengu56's Avatar
Are you saying that you don't have a third brake light on your rear window?
That's odd.. :/
Old Apr 5, 2008 | 04:32 PM
demzzy's Avatar
thats wut im saying.. my xA is the 2004 model
Old Apr 5, 2008 | 04:39 PM
demzzy's Avatar
how do i go about runnin a 3rd brake light cable
Old Apr 5, 2008 | 05:30 PM
cobb's Avatar
Id run the wire from either fixture brake light wire then up through the side to celling to the opening. Strange no 3rd light, I think those are required since 1986.
Old Apr 5, 2008 | 05:31 PM
SquallLHeart's Avatar
your 2004 should have a 3rd brake light.... the wiring should be there.
Old Apr 5, 2008 | 05:32 PM
demzzy's Avatar
where do i look plz?
Old Apr 5, 2008 | 05:54 PM
i would start off here:
https://www.scionlife.com/forums/viewtopic.php?t=138456
look up the stop light diagram pdf.. find the connectors.. and then open up the connector location pdf.
Old Apr 5, 2008 | 10:29 PM
demzzy's Avatar
hmmm...
Old Apr 5, 2008 | 10:39 PM
demzzy's Avatar
thanks for the locations of that manual.. will go lookin for that cable now
Old Apr 5, 2008 | 10:53 PM
demzzy's Avatar
do i take the cover off right there by the inside of the door to see if the wire is there?
Old Apr 5, 2008 | 11:18 PM
demzzy's Avatar
ok i found the blue wire.. was tryin to figure out where it goes tho.. but dunno yet..
Old Apr 6, 2008 | 01:15 AM
demzzy's Avatar
found the blue wire... but it goes to the back door.. and connects to this silver lookin rectangular thing
Old Apr 6, 2008 | 01:18 AM
demzzy's Avatar
its goes to the license plate
Old Apr 6, 2008 | 02:35 AM
cobb's Avatar
Dude, you drill a hole through the hatch to pass the connector through to the third brake light. On the inside hatch area wher ehte nozzle is you should see a hole and a hole or plastic cover. Back there is where the plug should be if they did away with the 3rd brake light.
Old Apr 6, 2008 | 02:38 AM
demzzy's Avatar
yes i see a whole there ...but no cable.. i trsced back the cable..and is in the back door.. where the license plate lites r....... do i have to splice or something ?
Old Apr 6, 2008 | 03:33 PM
cobb's Avatar
Dude, not unless you want it to light when you turn on your parking lights. The cable is suppose to go through the black tube that connects the hatch to the roof of the car parallel to the squirt tube for the rear windshield washer.
I would run a cable from the rear lamp housing to the brake lead on the parking/brake light to your spoiler.
Old Apr 6, 2008 | 04:06 PM
demzzy's Avatar
see thats the thing.. it isnt run along with the squirt tube.. i can see where the squirt tube goes... but the blue cable... goes up abit.. thn merges with another cables... and runs right into the trunk door.. i wanted to know if i disconnect it from the connector if it would affect anything.. cuz its clear that the connections r there.. just being used with something else? i dunno... i wanna know if i disconnect it.. and just run the spoiler to that connector if it would work..
Old Apr 7, 2008 | 08:30 AM
PagingDRb's Avatar
dude, thats some wierd ish, I too have an 04 and my third brake light is sitting smack in the top center of the window. Maybe its some sort of conspiracy.
My spoiler should be coming in a few days, hope i dont have any trouble. Well let us know how it works out.
