Transmission ideas!!!
Old Apr 5, 2008 | 04:41 AM
CRAracer05's Avatar
Default Transmission ideas!!!
This idea cam t me the other when I was getting a quote for my dsm tranny. Almost all of the gears used to change ratios in DSms are from evoIII trannys. So i'm wondering if its possible to swap like a 2az camry 5th gear to lower rpms fro highway cruising. I can almost guarantee that this can be i just don't have the resources to pull parts numbers and gear ratios of all these cars to find something to try.
Old Apr 5, 2008 | 05:24 AM
krazylowgsx's Avatar
man.. its crazy you posted this bc i was just thinking about it myself! i had a dsm as well (97gsx...hence my screen name) and i had my dsm trans fully built and added a longer 2nd and 3rd gear! with the tc, i'm sure there is something that would work...its just whos got the ***** to try it out..lol. i'm more concerned with beefing it up, and making it bullet proof like my dsm tranny was. i went thru 3 tans in my eclipse, and finally shelled out the money to have one built to handle what my car was putting down (511whp) and i never again had an issue with the tras. i was at the 1/4 mile track EVERY weekend, and sometimes tues nights too since that was the test and tune night! i beat the ____e out of that car tho
Old Apr 5, 2008 | 11:54 AM
CRAracer05's Avatar
I know i wish I had a toyota microfiche or something. there has to be something you can do. I mean even on my pitbike i swapped the primary gears out t have a higher top speed after I built the motor granted thats way easier.
Old Apr 5, 2008 | 06:23 PM
I'm sure it will only be a matter of time before built trans are available for the tc. the stock form has been proven to hold 500+whp on the dyno and I haven't seen to many of them run down the track, but I'll tell you right now... I break a tranny with in the first month of my cat being completed.. lol. I'm all about going out to the track.
Old Apr 17, 2008 | 01:02 PM
CRAracer05's Avatar
Well finally got around to doing some research. An 07 camry has a slightly taller 5th gear at .731 rather the tc's .775. Although its not a huge diffenrence I bet it would still be nice to drop some rpm's off at 65mph highway speeds.
Old Apr 17, 2008 | 08:17 PM
Steventc07's Avatar
the main difference is the camry's final drive ratio. ours is 4.29:1 and theirs is 3.94:1, this allows us to take off faster but suffer with highway mileage
Old Apr 18, 2008 | 02:41 PM
CRAracer05's Avatar
The 5th gear should still help though, correct?
Old Apr 18, 2008 | 02:51 PM
chicotunner07's Avatar
somebody should just try to bolt on a whole camry tranny and see how it works on the tc, especially a boosted tc
Old Apr 18, 2008 | 04:11 PM
AAG's Avatar
AAG
DeepSouth Scions
I agree, so who's gonna be the guinea pig? I hate my 5th gear it revs way to high on the hwy.
Old Apr 18, 2008 | 05:55 PM
flint_08's Avatar
Maybe I am just stupid ... but why is it not possible for us to just swap the tranny from the Camry? Is it possible but just no one has completed it, or are there other factors that dont allow for it?
Old Apr 18, 2008 | 06:22 PM
Scoobasteve4132's Avatar
Maybe cause it's some good $$$... If found em near $1500... I'll deal w/ some higher rpms...
Old Apr 19, 2008 | 02:51 AM
canrollya's Avatar
i actually thought of this a long time ago ......i did the research to change them out but ran low on time constraints when putting my trans back together after putting in the lsd.
Old Apr 19, 2008 | 03:11 AM
Steventc07's Avatar
yes, it would. IMO the gearing is fine until 5th. I would like a taller overdrive but still want the low gearing for acceleration. A gear even taller than the camry's 5th would be better i think
Old Apr 19, 2008 | 05:26 PM
CRAracer05's Avatar
Definately agree with you on a taller gear than the camry,but my whole deal is trying to be cost effective. I really wanna go order the gear from dealer and swap it out.
Old Apr 19, 2008 | 05:32 PM
Ace83's Avatar
Ronin Scion
watching
Old Apr 19, 2008 | 05:36 PM
SHDWtC's Avatar
If someone is gonna make this happen...possibly a kit or a swap, they should have an NA version and a Turbo version...the NA being just changing out the 5th gear ratio and leaving the final drive and the Turbo version changing both!
Old Apr 19, 2008 | 05:53 PM
Steventc07's Avatar
+1, and couple w/ a removal of the speed limiter...lol
Old May 4, 2008 | 05:47 AM
Bozuzu's Avatar
yeah to hell with saving mileage, I'd like to get some taller gears in there to realize some speed. what the hell is the point of me dropping 4 large into my car on a supercharger and go kart suspension to get 300 hp if I can only go 120 mph? with 300 hp I want to go to buttonwillow and hit 160 on the back straight! what does chris rado's cup car use?
Old May 4, 2008 | 05:53 AM
Bozuzu's Avatar
well to answer my own question he uses a lenco setup with planetary gears. hugely troublesome and CRAZY expensive, but if you can get it to fit and work you get to choose each of your drive ratios, which is sick!!
http://www.lencoracing.com/HowaLENCO...IOSmaster.html
evolving_machine
Oct 21, 2023 01:16 PM
Fisqual
Sep 22, 2015 05:51 AM
henry54321
Apr 22, 2015 03:02 AM
kgoerbig
Apr 17, 2015 12:40 AM
Zman
Apr 10, 2015 08:04 PM
