Need Help... is +30 offset on a 7 inch wide rim doable???
i got an idea brewing on some rims and they are 1? x 7 with a + 30 offset .... was wondering if its doable and will clear the brakes.... anyone?? is that to low of an offset to use safely for DD and possible track use??
i'm running 17x8.5 et+32 for daily and autocross. however, if you plan on running 245's or higher, you have to roll your fenders and run negative camber out of spec. i'm running a lot of negative camber so i don't rub on every little bump.
no i dont plan running such a high width of a tire... most the rims in this offset im looking at are 29-35 offset in 7.5 or 7 inch... 16's and 17's... ive only once considered an 18 but i knew it was to heavy of a wheel for DD fun...
Luisfc1972
Scion tC 1G Wheel & Tire
10
Oct 23, 2015 05:49 AM
mischman
Sep 15, 2015 03:38 PM
dixonge
Jul 11, 2015 11:02 PM
