Excessive Clutch Noise
Old May 12, 2008 | 03:08 AM
uber-xA-RS2's Avatar
Default Excessive Clutch Noise
Hey guy's!
I need some input here. Over the last few months I have been having an increasing issue with my clutch.
Last July I installed a Spec Stage 2 Clutch and A new flywheel in preparation for future upgrades. That upgrade is right around the corner in the form of the turbo.
The issue I am having is this.
When I release the clutch pedal in first gear to get the car moving, I get this horrid groaning and howling noise from the transmission. I know it has to do with the clutch.
I release at 1500 RPM (stock release speed) and under initial torque the noise is present. This is true for Reverse, and First Gear. Any other gear changes and the howling is not present. The noise is also present when taking off from a hill.
This noise is also accompained by a light vibration in the clutch pedal during the noise.
The throwout bearing does not make any noise when depressed in neutral, no bird chirping or anything. I do get a hum during shifting through all gears and I am sure this is just the throwout bearing contacting the heavy duty pressure plate.
What I need to know is:
Is this a faulty throwout bearing? (bearing was replaced with a new one on install)
Or is this a severe case of clutch chatter?
Either way I look at it, I will have to drop the transmission to replace the effected parts. And I want to do this before I put my turbo in.
Your input is highly appreciated in this case, and the more the merrier.
Old May 13, 2008 | 05:18 PM
frankenstienheadonwheels's Avatar
yikes my tranny did that before it blew up, mine turned out to be bad bearings that whent on to destroy my trans because i kept driving on it(dumb i know) i hope thats not whats wrong with yours but thats what mine turned out to be. grinding noise while driving but goes away when clutch is pushed in?
Old May 17, 2008 | 07:25 PM
Scorpius01's Avatar
Default Re: Excessive Clutch Noise
Originally Posted by uber-xA-RS2
Hey guy's!
Possible for a new throwout bearing to go out? unlikely......but I have seen it. Did you do the install? did you take a torque wrench to the pressure plate bolts, flywheel bolts?
Old May 18, 2008 | 02:44 AM
I did the install myself and torqued everything down to Toyota specs.
Regardless of what the issue is, the clutch, pressure plate, throwout bearing, and flywheel are being replaced tomorrow. :D
Col168c
27
Apr 9, 2020 10:48 PM
SpaceCaptain
May 11, 2015 06:24 PM
nazblue5807
Apr 11, 2015 12:20 AM
gularti
Dec 4, 2014 01:21 PM
eric_m
79
Mar 17, 2013 12:21 AM
