rev limiter ?
Old May 15, 2008 | 05:35 AM
alucas8892's Avatar
Default rev limiter ?
Is there one on the 08's. If there is, is it adjustable?
Old May 15, 2008 | 05:40 AM
draxcaliber's Avatar
yes, pretty much all cars have a rev limiter or fuel cut off, and you can remove it, probably with a piggyback ecu, and if you do, there is a very good chance you will f-up your engine.
is there a particular reason why you want to raise the rev limiter?
Old May 15, 2008 | 07:01 AM
alucas8892's Avatar
actually I want to lower it to like 6100ish where redline is.
Old May 15, 2008 | 07:07 AM
uhm...you make your peak horsepower at 6000 rpms, which means that is where you want to shift, having the rev limitor set at 6100 rpms means that...you'll end up bouncing off the rev limitor and screwing yourself if you shift even a moment too late.
Old May 15, 2008 | 04:54 PM
RSracer's Avatar
Why in the hell would you want to do something as stupid as that?!?!
I think you should have stuck with an automatic
umnitza
Sep 1, 2015 08:06 PM
carid
Aug 7, 2015 11:32 AM
kanundrum
Regional - Mid South
Aug 4, 2015 04:23 AM
JonathonK
Jul 15, 2015 06:04 PM
