s2 or s4 eD sub?
Old May 15, 2008 | 11:18 AM
808tC's Avatar
Default s2 or s4 eD sub?
i have a Sony XM-2252HX Amp
http://www.teamrocs.com/reviews/amplifiers/XM2252HX.htm
which eD sub (s2 or s4) should I get to match it?
also, how would I tune it?
and finally would this fit in the spare tire?
sorry for the noob questions.
Old May 15, 2008 | 02:26 PM
blazeplacid's Avatar
single 2 ohm is what you need
the specs says it will do the same wattage at 2 ohm and 4 ohm but id do the 2 ohm
tuning is the last step. Tuning depends on your box/box size/ placement of the sub/ other speakers.
the amp should fit in the spare tire
Old May 15, 2008 | 05:43 PM
1DarkTC's Avatar
NO......you want the S4...that amp is a 2 channel amp so when you bridge it the 4 will drop to a 2 ohm load. If you have 2 ohm sub and bridge it then that will drop it to a 1ohm load which that amp CANNOT handle.
Old May 15, 2008 | 05:47 PM
1DarkTC's Avatar
Not to mention..that amp is pushing double the recommended RMS power for the SQ10 (is that the sub you're getting?)....if so then I would make sure you keep that gain at 1/2 or less as to not overpower the sub.
Old May 15, 2008 | 08:10 PM
808tC's Avatar
thats the amp I already have and I already got the stealth box made for the ed 10" sub. Yea I know its 600w which is double the ed sub, but thats why I came here for help in tuning it so i wont blow the sub. lol
sooo s4 it is?
Old May 15, 2008 | 09:06 PM
1DarkTC's Avatar
I know...it will work..I was just telling you to make sure you keep the gain down. Let us know how it sounds when you get it all hooked up!
Old May 16, 2008 | 12:32 AM
BZinn1's Avatar
Burn a tone disk to what ever Hz level you want the sub to play at......I used a 50 Hz tone........put it in the player withthe gain all the way down........turn deck up to 75% of the volume.
Use the formula of the amount of watts you want to goto the sub x the ohms and then take the square root of that........that will give you the AC voltage that needs to goto the sub from the amp.
Use a vilage tester and put it on the pos and neg terminals and turn up the gain till you get the AC volts form the mathmatical figure........
that will give you a non clipped signal up to 75% of the stereo volume.........that is my understanding at least and what I did with my amp and speakers and they are clear and loud with no clipping.
Old May 16, 2008 | 01:18 AM
trialsindude's Avatar
Strictly Scionized
He's getting a single sub, no matter if it is 2 or 4ohms single voice coil, the amp will see that 2 or 4ohm load. Also it gives the same power at both loads.
GAIN **** is not a VOLUME ****. 1/2, 3/4, 5/8, all arbitrary to the HU output voltage, you are matching the gain **** with the HU preouts.
Old May 16, 2008 | 01:33 AM
1DarkTC's Avatar
lmao...you're right...I posted that right before I went to bed and I was out of it...I seriously don't know what I was thinking of.
