Flat paint clear coat protectant?
Old May 19, 2008 | 06:46 PM
Number2's Avatar
Default Flat paint clear coat protectant?
So in painting rampage that started with the tear drop center piece, I have begun painting a lot of my interior pieces. All have turned out well, say for the center console, interior side skirts and kick panels. These are all flat black pieces.
The problem is, is that when practicing with the clear coat (to protect from scratches) I get a glossy finish. Without this, the flat black enamel scratches and easily shows marks.
Any advice on what to do?
Old May 19, 2008 | 06:57 PM
tc702's Avatar
you can get clear coat that isnt shiny. it should say on the lid of the spray can "flat" i believe.
Old May 19, 2008 | 07:27 PM
Number2's Avatar
i went to two hardware stores and I couldn't find it. The store clerks were no help either. Lowes and Home Depot didn't have it.
can anyone else confirm that there is a flat clear coat?
Old May 19, 2008 | 07:39 PM
deflaytedwayz1's Avatar
Look for satin clear. It probably won't say flat on it. If you have an arts and crafts store around you should try them.
Old May 19, 2008 | 08:17 PM
BLUEMEANIE's Avatar
Team Hamster
^ yep. Satin, flat or matte its all the same.
Old May 19, 2008 | 09:21 PM
Number2's Avatar
satin is glossy
Old May 19, 2008 | 10:15 PM
tweetertc's Avatar
usually... to get "flat" clear coat... your going to need to go toa body shop supply store... and buy it by the pint or gallon and use a spray gun... you dont get the same effects out of a rattle can....
Old May 19, 2008 | 11:30 PM
tcdaily's Avatar
satin is like a mixture of flat and shiny it's a dull shiny kind of.. professionally you have to add an additive to it to make sure it's a "flat" look..
Old May 19, 2008 | 11:39 PM
Toast89's Avatar
I live in Michigan and all the Lowes carry Valspar Flat Clear Cloat. If you cant find it there in your area, most art supply stores carry flat matte clear.
Old May 22, 2008 | 03:36 AM
Number2's Avatar
^^^ does that come in the spray can? I'm going to call around if it is.
also, if it is only in the form of a can and I have to paint it on, what kind of results can I expect? I ordered new center console stuff, but I will try and do this to the kick panel and door trim piece if possible.
Old May 22, 2008 | 02:45 PM
BZinn1's Avatar
Krylon Matte Clear 3530 is what you need........although it is not 100%flat anymore it is all that is left.there used to be a better Flat Clear on the market that I used to use for art retoration,but now all i can use is matte or mix my own which is a pain......
Satin can go on with dull finish as well,but after a couple of coats it is more of a shine to it.......
Old May 22, 2008 | 05:55 PM
Number2's Avatar
tHANKS,
I'll check it out tonight, hopefully.
Old May 23, 2008 | 01:34 AM
Toast89's Avatar
Yeah, the Valspar Flat Clear is in a spray can.
Old May 23, 2008 | 02:21 AM
Number2's Avatar
krylon makes model #7120 (i believe) that is a matte clear coat. Picked it up at a modeling/art store. $5/can. Works like a charm.
the valspar I saw was only online, came in a standard paint can (not spray), and is super expensive.
SoKrispy
Scion tC 2G Aero & Exterior
Oct 13, 2015 03:48 PM
StxArOne
Jul 13, 2015 06:25 PM
x2x3
Jul 12, 2015 12:44 AM
oogoom
Scion tC 1G ICE & Interior
Jul 11, 2015 11:57 PM
wesley_t
Dec 18, 2014 06:59 AM
