camber problems.
Old May 20, 2008 | 07:58 AM
pr1morida's Avatar
Default camber problems.
i made the mistake of lowering my car without getting my wheels aligned afterwards. it has since been a few thousand miles and the inside of my tires (all 4) are worn down pretty good. it is the inside inch that is worn down to no tread. do i have to by a new camber kit to fix the tilt or can i just get an alignment and have it be fixed. need help. thanks guys
Old May 20, 2008 | 08:17 AM
yesti's Avatar
dang, you must've gone real low. Camber is adjustable so you may get away with having an alignment done and not need any aftermarket parts.
Old May 20, 2008 | 08:26 AM
pr1morida's Avatar
no i just got h-techs put on...not too bad
Old May 20, 2008 | 09:53 AM
krazyscion's Avatar
h-techs camber can be corrected with alignment... as far as i know
Old May 26, 2008 | 05:36 AM
Buckets's Avatar
buy new tires and get an alignment
Old May 28, 2008 | 10:20 AM
przemko's Avatar
i'm dropped on ssp and my camber in the back is 2.5 on both wheels so i ordered camber links from hotchkis
Old May 28, 2008 | 03:26 PM
Dr_Isotope's Avatar
Jesu Cristo. I've only said this a tousand times, so what's one more? Toe out wore your tires, not camber. You can run -3.0º of camber all the way around and your tires will wear just fine. But even 1/16" toe out will eat the insides of your tires off.
Get the toe corrected.
Old May 28, 2008 | 04:04 PM
NurSpec's Avatar
rotate tires and alignment
Old May 29, 2008 | 12:59 AM
mystik's Avatar
CinSity Scions
just straight up get a full alignment which does camber and toe...and of course, buy new tires...wouldnt want to have a flat anytime soon >_> no aftermarket camber links needed
yupinmytC
22
Jul 27, 2024 07:08 PM
Darrenohooligan
Sep 26, 2015 07:21 AM
domincnTC
Aug 4, 2015 01:47 PM
Subaru86
Jul 31, 2015 04:33 AM
Andrew75
Jul 27, 2015 09:37 AM
