Strange HID Question
Old May 22, 2008 | 09:41 AM
jamazing's Avatar
Default Strange HID Question
Hi everyone,
I installed my Mobile HID 6K kit a few weeks ago. I have been noticing that when I turn my headlights on, my radio reception becomes fuzzy immediatly. Now I know that the ballasts create a pretty large magnetic field, but is that what is causing this? Has anyone else noticed anything like this with a HID kit? Finally, are there any fixes for something of this nature?
Old May 22, 2008 | 11:08 AM
operatic's Avatar
If the ground to the relay harness is on the chassis itself, put it on the negative post on the battery. That will usually fix the problem.
Old May 22, 2008 | 11:43 AM
datdude1119's Avatar
x2
Old May 22, 2008 | 12:15 PM
jamazing's Avatar
The ground wire is already on the negative battery terminal. Any other suggestions? But I do appreciate your fast responses!
Old May 22, 2008 | 01:13 PM
nforce4's Avatar
What brand HID kit did you get? I read from another forum that certain ones will have this result.
Old May 22, 2008 | 01:16 PM
nforce4's Avatar
Heres a link to some info. Maybe try checking your connections. Make sure everything is firmly connected, also try using different ground connections on your car. Good Luck!
http://tristate.apogee.net/lite/lhiradi.asp
Old May 22, 2008 | 03:11 PM
jamazing's Avatar
Its the Mobile HID kits that a ton of people on here use. The interfence only happens when I'm in the sticks or vallys also...never at my house or in the city.
Old May 22, 2008 | 03:39 PM
JNasty's Avatar
maybe its not the HIDs then i have the same kit and dont have this problem. do u have an s2k antenna they have good reception but i have found its not as good as the stock antenna so maybe when your in the places where there is less reception it fades out even more. Just a thought
Old May 22, 2008 | 04:03 PM
jamazing's Avatar
Yeah its not really a big deal to me I just found it to be odd. Where did you mount your ballasts? It could be where I put mine, one velcro'd to the top of the fuse box and the other fastened the same way to the car on the body directly in front of the passanger headlight. I did it that way for easy removal if ever a warranty issue.
Old May 22, 2008 | 04:06 PM
JNasty's Avatar
my ballasts are on both sides of the bumper bar. its hidden and no real water issues there either. i would prefer them there over a lot of places i see people putting them on here. the only thing is u have to take off the front bumper to do it.
Old May 22, 2008 | 04:10 PM
JNasty's Avatar
its off topic but ive noticed from my own post and others posts that whatever color your tc is everyone that has the same color tc replys to your post its like we feel like we have a secret connection because of the colors of our cars lol
Old May 22, 2008 | 04:44 PM
jamazing's Avatar
Haha you're right about that one....maybr one day if I have extra time I will reroute mine there. Where is your relay @? Snap a pic sometime if you don't mind and pm it to me.
Old May 22, 2008 | 04:48 PM
JNasty's Avatar
yea ill do that but i gotta get another digital camera my last one broke
Old May 22, 2008 | 10:22 PM
mattieg's Avatar
I have the same problem with mine. I also have an avic-d3 installed. Do you have a factory radio or is after market?
Old May 23, 2008 | 05:19 AM
Tom11x's Avatar
i have the pioneer d3 too. its been making a lot of noise every time i turn on my hid. I got the ground loop isolator it helps but its still there. so far i brought three different brands. one at the local audio, one at the swapmeet and just bought one today walmart. nothing works. there is still noise in my front and rear. im running a 4ch alpine for the speakers and performance tek for my kicker. I was messing around with it about 2 hours ago and now all my speakers doesnt work so i literally took everything out. hopefully to fix the problem tomorrow.
any luck with any isolator
i got the
install edge ground loop isolator
scoshe ground loop isolator
dnf ground loop isolator
the best is the dnf. but theres still noise
Old May 23, 2008 | 01:31 PM
jamazing's Avatar
I believe its strictly from the magnetic field generated from the transformers (ballasts)
Old May 23, 2008 | 09:10 PM
ichibansf's Avatar
I would get that ballast away from your fuse box. A lot of us have the driver's side ballast mounted on the sidewall near the airbox.
bootlgr
Jan 26, 2016 01:22 AM
Greg S
May 28, 2015 12:46 AM
Scionxa180
Mar 13, 2015 04:39 AM
TotalChaos
13
Feb 4, 2015 10:24 PM
xBassist
9
Jan 21, 2004 07:34 PM
