Digital to Analog TV Box Converter Problem
Old May 23, 2008 | 04:04 AM
7thgear's Avatar
Default Digital to Analog TV Box Converter Problem
I just bought a converter box at RadioShack and the model is DigitalStream DTX9900. I was able to get it hooked up and everything and during the setup process, it's searching/scanning for channels, but once it's done, it was unable to find any channels. I don't have cable or satellite, I just have regular broadcast TV with the rabbit ears. We also have an outside antenna and we tried hooking it up to that, but it didn't work either.
Any ideas?
Thanks.
Old May 23, 2008 | 06:32 AM
13edge's Avatar
It should work fine with your outdoor antennae. Wierd. Do you know for certain that they are broadcasting in digital in your area?
Old May 24, 2008 | 12:58 AM
jct's Avatar
jct
you have to buy a digital broadcast antenna
Old May 24, 2008 | 04:19 AM
13edge's Avatar
That is really wierd. I've been to reviews for his particular model, and everyone seems to just be using it with their existing antenna. Even the video showing you how to hook it up uses the existing antenna. Try the digital broadcast one if it isn't too expensive, I guess.
Old May 26, 2008 | 06:12 PM
RAAB3485's Avatar
You shouldn't need a different antenna at all to pick up digital channels. I would say you might have a bad tuner box. Also, consider that digital broadcasts don't work the same as analog, if you live more than about 65 miles from where the signal is broadcast from, you will never pick up a signal. It isn't like analog where the quality just gets worse, once you are outside that radius, it just stops working altogether.
Old May 27, 2008 | 02:04 PM
HeathenBrewing's Avatar
Default Re: Digital to Analog TV Box Converter Problem
Originally Posted by 7thgear
...Any ideas?
Learn the proper place to put posts like this.
evolving_machine
Feb 27, 2015 09:53 PM
ninoTc
Jan 24, 2015 05:02 AM
lunchbx05
Dec 11, 2014 06:13 PM
rcflyer15
Dec 5, 2014 05:15 PM
