Broken Sparkplugs
Old May 26, 2008 | 10:29 PM
Somack_59's Avatar
Default Broken Sparkplugs
So I was tightening my spark plugs to 20fttq as the instructions told me to and then I heard a snap now the thread of the spark plugs is stuck inside the hole. Need help to get it out. Any suggestions with out going to the auto shop. ???
Old May 26, 2008 | 10:46 PM
KillaSpiceTSW's Avatar
Tap and drill..
Old May 27, 2008 | 01:47 AM
egtc88's Avatar
did it tell you to torque it to in. lbs or ft. lbs?
Old May 27, 2008 | 01:49 AM
Somack_59's Avatar
it said 20 ft lbs
Old May 29, 2008 | 10:37 PM
etoomey3's Avatar
20 ft. lbs? where'd you get those torque specs? sounds kind of high? from now on just tighten them by hand w/a ratchet and stop when it gives you resistance.... you could use a bolt extractor set to try and get the plug out......and you could try a re-threader kit for the spark plug hole, or a heli-coil kit which re-threads the hole, good luck man
Old May 30, 2008 | 05:02 AM
przemko's Avatar
i don't think that you can just drill it and tap it cause what about chips that will get into combustion chamber...
In my opinion the whole cylinder head need to be removed to fix it
Old May 30, 2008 | 06:05 AM
egtc88's Avatar
i agree with przemko
Old May 31, 2008 | 11:37 PM
Somack_59's Avatar
thanks for all your help guys...i got the broken plug out by a bolt extractor and the metal shavings with a magnet....
Old Jun 2, 2008 | 07:05 PM
combatsteve's Avatar
wow that sounds like you avoided a disaster there.
Old Jun 3, 2008 | 02:49 AM
Somack_59's Avatar
yea i noe...
Old Jun 3, 2008 | 02:50 AM
Higgy's Avatar
Could it have maybe been inch lbs and not ft lbs?
Old Jun 3, 2008 | 02:54 AM
Garage1217's Avatar
Standard for ALL gasketed spark plugs is 13 ft lbs, or 1/2 turn past hand tight.
Old Jun 3, 2008 | 06:26 AM
Somack_59's Avatar
ill scan the instructions as soon as i can...
Old Jun 3, 2008 | 02:50 PM
Higgy's Avatar
I didnt know at all. I just know at work a lot of mistakes people make is using the wrong torque value. I know if Garage1217 says ft lbs its ft lbs because he knows his shiz.
yhwhdesign
Jun 11, 2021 03:34 PM
jeremydoc
Sep 16, 2015 11:31 PM
Btp907
Sep 15, 2015 02:54 AM
Mica09
Jul 25, 2015 05:28 PM
