Stalling Problems
Old May 30, 2008 | 07:21 PM
MixedWun's Avatar
Default Stalling Problems
Hey guys my second car my 1993 honda civic lx (5 spd) is having some problems. I understand if you dont post because its a tc but if u can could u maybe point me in the right direction?
The car cranks up with no problems, and will remain that way. When I release the gas, like coming to a stop or just coasting, the car will begin to shake a little. It will either stall or stop shaking after a few seconds.
Old May 30, 2008 | 08:22 PM
AAG's Avatar
AAG
DeepSouth Scions
www.honda-tech.com (but make sure you search or you will get FLAMED!!)
On a serious note check your timing
Old May 30, 2008 | 08:23 PM
Thorium06's Avatar
Check injectors, spark plugs, and throttle cable tension. All are good places to start
Old May 30, 2008 | 08:49 PM
MixedWun's Avatar
thanks guys and yeah i have it on honda tech as well, but i figured it couldn't hurt to ask over here as well since I do own a tc as well .
Old May 30, 2008 | 09:19 PM
NurSpec's Avatar
is it modded? You still running stock ecu?
Old May 30, 2008 | 11:58 PM
sciontc_mich's Avatar
Default Re: Stalling Problems
I bet if you just lightly press the gas you'd not stall? It's probably the idle air control valve/motor (IAC, for short). I would check your timing as well, but the IAC probably went bad. I've had it happen to other civics.
Old Jun 2, 2008 | 06:26 PM
MixedWun's Avatar
Its still stock other than an intake.
Yeah if i give it any gas at all its fine, its immediately after i release it that it chokes and decides whether it wants to stall or not. Thanks for suggestions.
Old Jun 2, 2008 | 07:29 PM
miniaznkid's Avatar
or go to www.superhonda.com theres a forum there
Old Jun 2, 2008 | 11:44 PM
yeah that definitely sounds like the idle air control motor/valve. Any honda civic repair manual will tell you how to diagnosis it and test it out. It's either checking the resistance of the motor, or using a vacuum gauge to test it. but, Chilton has a whole line of repair manuals, good stuff.
Old Jun 3, 2008 | 01:19 AM
silverstreaktc's Avatar
put the car in gear?
eric29
15
Apr 26, 2016 07:27 PM
Mkn
Mar 26, 2015 01:47 PM
Nicole412
Mar 23, 2015 06:26 PM
andergtr
Jan 23, 2004 12:43 AM
andergtr
27
Jan 8, 2004 05:55 AM
