Notice about DIY cabin air filter
Old Jun 6, 2008 | 01:27 AM
Makaveli's Avatar
Default Notice about DIY cabin air filter
There is a reason why it doesn't come with one stock (exclusively the tc). "The Scion tC cannot be retrofitted with a Cabin Air Filter or Case Part Number due to cooling system operations"
http://www.toyotaownersonline.com/pu...rfilters06.pdf
Old Jun 6, 2008 | 01:36 AM
trialsindude's Avatar
Strictly Scionized
Old Jun 6, 2008 | 02:08 AM
Yanki01's Avatar
mine blows hard (lol) just the same as it did before, no problems here!
Old Jun 6, 2008 | 02:15 AM
krazyscion's Avatar
i don't notice any difference in mine...
Old Jun 6, 2008 | 02:57 AM
Patchnauty's Avatar
nor did i, its worth it to have it, when i drive by skunks i dont smell it as bad
Old Jun 6, 2008 | 03:03 AM
ScionJim23's Avatar
mine works perfect still....plus, you would be shocked how much debris it catches each month.....gross stuff
Old Jun 6, 2008 | 03:04 AM
ninjaionsobe's Avatar
but they offer it with a psi upgrade to the system. They offer it to me when i took it in one time.
its under the tbs i think
Old Jun 6, 2008 | 04:58 AM
Number2's Avatar
don't you know? breathing clean air voids warranties.
Old Jun 6, 2008 | 05:57 AM
Ryfly's Avatar
LOL, it's pretty bad thing to do
Old Jun 6, 2008 | 06:44 AM
sarahsaurusss's Avatar
ugh....not this crap again.
Old Jun 6, 2008 | 12:42 PM
iNck's Avatar
x2
Old Jun 6, 2008 | 12:44 PM
CarbonXe's Avatar
How is the A/C system going to work harder? It restricts the airflow AFTER everything else, the A/C system never detects actual airflow in the vents, so it shouldn't effect anything.
If it has to do with having it work for a longer period of time to keep the car cool, then does having an open window void the warranty also?
Old Jun 6, 2008 | 01:51 PM
engifineer's Avatar
This is not only ancient news (brought up about a million times, even in the DIY cabin filter thread), it does not put significant strain on the system, especially using the DIY filter everyone uses, which is much freer flowing than a toyota filter.
And I believe the main issue was just that the cars AC did not cool as well (or they didnt think it was) with the extra filter in the system. I can take mine in and out and there is zero noticeable difference.
And the restriction the filter would add would be minimal compared to running the AC with most of the vents closed, so it is not going to hurt the system to do so.
Old Jun 6, 2008 | 03:00 PM
Number2's Avatar
I apologize. I agree ^^^ This topic has been covered many times. I've done this mod, following the diy on this forum. Your car will be fine with a cabin filter.
Old Jun 7, 2008 | 05:22 AM
highvoltage1's Avatar
IBTL
Old Jun 7, 2008 | 06:22 AM
Number2's Avatar
Originally Posted by highvoltage1
IBTL
^^^post count +1
Old Jun 7, 2008 | 06:42 AM
GammaTNT's Avatar
if you see what get trapped in the filter. You will not want to drive without one.
Old Jun 7, 2008 | 09:13 AM
Ryfly's Avatar
IBTL
^^^post count +1
^^^^^ IBTL x2
Old Jun 7, 2008 | 10:05 AM
Ace83's Avatar
Ronin Scion
x2, you dont see only dust but also same stuff you see on your grill and radiator
airmankevin1
Feb 14, 2018 01:23 PM
miguelishu
Mar 9, 2015 02:38 AM
m1keteam
Jan 29, 2015 07:56 AM
cid_mcdp
Jan 5, 2015 02:45 PM
Godfryness
Jan 2, 2015 11:18 PM
