Notice about DIY cabin air filter
There is a reason why it doesn't come with one stock (exclusively the tc). "The Scion tC cannot be retrofitted with a Cabin Air Filter or Case Part Number due to cooling system operations"
http://www.toyotaownersonline.com/pu...rfilters06.pdf
How is the A/C system going to work harder? It restricts the airflow AFTER everything else, the A/C system never detects actual airflow in the vents, so it shouldn't effect anything.
If it has to do with having it work for a longer period of time to keep the car cool, then does having an open window void the warranty also?
This is not only ancient news (brought up about a million times, even in the DIY cabin filter thread), it does not put significant strain on the system, especially using the DIY filter everyone uses, which is much freer flowing than a toyota filter.
And I believe the main issue was just that the cars AC did not cool as well (or they didnt think it was) with the extra filter in the system. I can take mine in and out and there is zero noticeable difference.
And the restriction the filter would add would be minimal compared to running the AC with most of the vents closed, so it is not going to hurt the system to do so.
Originally Posted by GammaTNT
if you see what get trapped in the filter. You will not want to drive without one.
airmankevin1
Feb 14, 2018 01:23 PM
cid_mcdp
Jan 5, 2015 02:45 PM
Godfryness
Jan 2, 2015 11:18 PM
