Cig Lighter Outlet Problems
Old Jun 7, 2008 | 08:05 PM
STNC's Avatar
Default Cig Lighter Outlet Problems
Ok, So I have a 400 watt power inverter in my hatch, its connected to a Wii, 20" lcd monitor, and a tiny little vga to a/v converter.
The problem: I had a setup of 2 radio shack 12v cig cables that ran around the car to the hatch, but whenever i would turn on the inverter, it would flip out. However! When I plug the inverter an the setup into the front cig lighter outlet, it works fine.
I noticed that the extender cable thickness is thinner than the one for the power outlet, and I think this is the cause.
Sooooo...
Does anyone know of any THICK cig outlet extender cords?
Old Jun 7, 2008 | 08:07 PM
O5_TRD_tC's Avatar
what do u mean it will 'flip out'?
Old Jun 7, 2008 | 08:11 PM
STNC's Avatar
starts beeping, i think its low voltage, either that, or the monitor just constantly resets itself
Old Jun 7, 2008 | 09:12 PM
Hyghgynx's Avatar
Whoa!! I just had a scary thought of you doing Wii Fit with your hatch open looking like a crazy person.
Old Jun 7, 2008 | 10:21 PM
STNC's Avatar
Well, I actually do have WiiFit in there, and yeah, so WiiFit mobile would happen!
Anyway!
I went to Lowes and Got 10 Gauge wire, because it looked like the same size when i held it next to the wire. It all works now. Except it just emits a constant high pitch tone. I'm gonna go look up what it is, but I'm gonna try attaching a few 14 gauges to each line and beef up the wire and see how that works. Otherwise all is proceeding well!
Any other suggestions
Old Jun 8, 2008 | 01:58 AM
Phlame217's Avatar
You have ground feed back (as to hi pitch noise). If you have a stereo be sure to ground everything at one spot, and be sure you have a good ground by scratching the painted area around the bolt, screw tap, etc even if its just a primered area.
ShawnMcc
Jul 11, 2015 11:07 PM
mdhyre
Dec 7, 2014 12:52 AM
