1NZ-FE cams?
Old Dec 6, 2004 | 07:44 AM
firesquare's Avatar
Default 1NZ-FE cams?
do they make cams for the 1.5? id tried a search on here but the search engine blows.
Old Dec 6, 2004 | 03:39 PM
WAFFLES's Avatar
I'm sure you could find someone to give you a regrind. Crower will do some.
Old Dec 6, 2004 | 03:40 PM
firesquare's Avatar
hmmm im lookin for a direct replacement with valvs and springs
Old Dec 8, 2004 | 12:56 AM
its_ikon's Avatar
the only thing is that the vvti makes it a mod that is not worth doing unless you are going for an all motor setup. i am sure www.elprototypes.com can give you all the information you will need about doing this.
Old Dec 8, 2004 | 01:11 AM
firesquare's Avatar
thanks for the info.
im lookin for a set up that i can use with a Blitz Blower. I completly forgot about the VTT-I
Old Dec 8, 2004 | 10:08 PM
BeQuietAndDrive's Avatar
All I can say is good luck.
Even the 2ZZ, Toyota's newest flagship 4 cyl, doesn't have cams.
I think the VVTi makes it much harder to create cams for...
Old Dec 8, 2004 | 11:00 PM
firesquare's Avatar
yeah probably.
i was thinkin this because my last car didnt have all those fancy bells and whistles (whistles, turbo :mrgreen
my last car was a 2.0 Zetec focus
Old Dec 9, 2004 | 12:23 AM
asirvr4's Avatar
for 1nzfe(xA. xB) only exhaust cam
but the intake cam cannot be replaced because its VVTi
in new corolla either intake or exhaust cannot be replaced because its VVTLi
Old Dec 9, 2004 | 01:37 AM
firesquare's Avatar
thanks for the info
but how do the hondas run aftermarket cams with their V-TEC?
Old Dec 9, 2004 | 08:08 AM
hotbox05's Avatar
cuz all their vtec is the same across the board
Old Dec 10, 2004 | 05:46 AM
SDstreetracer's Avatar
They still make cams for hondas with iVTEC, which is the same as vvtli. The reason they dont make cams for the toyota vvti or vvtli motors is the amount of r&d & cost is very high and the market is much smaller than for hondas. not enough people would buy them to make it worth while.
Old Dec 10, 2004 | 06:08 AM
firesquare's Avatar
sounds good then
Old Dec 23, 2004 | 07:53 PM
Tuning69's Avatar
VVTi Is a constantly changing cam setup. VTEC is a set spot where the cam come on... this is why there are VTEC controlers to change when it kicks in.
VTEC for example, is a cam changing system that utilizes multiple cam lobes on either one or two camshafts. VTEC shifts between a low cam profile and an high cam profile setting based on rpm. This system does improve peak power, and can raise red line (up to 9,000 rpm in S2000), just like an engine with racing camshafts, and increase power from 10-25%. However, the VTEC engine must rev at or above it's threshold rpm to really get things cooking. VTEC is used on Honda and Acura engines.
VANOS and VVT are used by BMW, Toyota, and various other car manufacturers. These systems allow earlier or later valve opening through cam phasing. The camgear changes the phase (or position) of the camshaft based on engine load, and is controlled by engine management system according to need, and actuated by hydraulic valve gears. At high speed for example, the inlet camshaft could be rotated in advance by 30 degrees or so to enable earlier intake opening. Unlike VTEC, these types of systems come closer to infinite variable timing, since they do not rely on changing cam lobes to vary timing.
Isn't the Last supra VVTi? If so .. HKS makes cams for it. Intake and exhaust
Old Dec 25, 2004 | 04:09 PM
firesquare's Avatar
not sure and anybody answer this?
Old Feb 5, 2008 | 04:24 AM
soros151's Avatar
^^^ vvtl-i is not the same as vvt-i.
vvtl-i is more like vtec, that's why cams can be made for the supra 2JZ.
Old Feb 6, 2008 | 12:12 AM
firesquare's Avatar
ooh brought back from the dead!
Old Feb 6, 2008 | 12:35 AM
soros151's Avatar
:D
Old Feb 7, 2008 | 04:59 AM
The 2JZ does NOT use VVTL-i.
There is no lift in that motor. 2ZZGE is the only Toyota motor with lift.
Old Feb 7, 2008 | 05:04 AM
soros151's Avatar
true, my bad. Not enough research on my part. I apologize.
Old Mar 4, 2008 | 03:20 AM
thatSCIONgirl's Avatar
Yes you can get cams as was said before ...both intake and exhaust ... but the vvti does make it diffacult to produce power w/o a cam controller and cam gears...we have been working on some for both th xB and tC
