2amp 1sub
Old Jul 1, 2008 | 11:08 PM
GammaTNT's Avatar
Default 2amp 1sub
i read this review of Infinity 12d VQ on "Car Audio and Electrion"
" I installed two Crossfire VR1000D amplifiers with a bridging module. Doing this will allow me to wire the 12d VQ's dual 4-ohm voice coils in parallel for a 2-ohm load. Two Crossfire VR1000D amplifiers wired with a bridging module at 2 ohms will deliver a throbbing 2000 watts of power!"
i want to have the same set up. How do i connect the wire 2 amp to 1 sub?
Old Jul 1, 2008 | 11:38 PM
lil_will's Avatar
ScionERA
That is referred to as "strapping" the amps together. Check this out...
http://www.eaudio.co.nz/CA2000Dplus_...no_graphic.pdf
Old Jul 2, 2008 | 06:12 AM
lbjshaq2345's Avatar
Just wire one amp to each VC...
Old Jul 2, 2008 | 03:06 PM
GammaTNT's Avatar
thanks for the replies.
I got one of the amp now, waiting to find another one ebay
Old Jul 2, 2008 | 08:41 PM
nebster's Avatar
bad bad idea, you need to make sure the amps are strapped so that you don't send different voltages to each voicecoil and blow out your sub
Old Jul 2, 2008 | 09:25 PM
trialsindude's Avatar
Strictly Scionized
I wanted to say the same thing but I wanted someone else to say it first! But then again he wanted to build a 9cube box for 2 12s...
Old Jul 2, 2008 | 10:10 PM
nodsetse's Avatar
It works fine if you do it right, you don't have to strap the amps in order for it to function correctly, you simply have to make sure both amp's outputs are at the same level. Either way is fine.
Old Jul 2, 2008 | 10:11 PM
nebster's Avatar
yeah but if you're off at all the sub will be fubar'd
Old Jul 2, 2008 | 10:30 PM
Real difficult to wire the subs up with the same ohm load. Anybody wanting to push this kind of power should at least know the basics of electricity. Voltage doesn't fluctuate per amp, it fluctuates throughout the entire car. Unless you have extra batteries, but that's a whole nother story.
And I don't recall wanting to build a 9cube box for two 12s? I recall posting a diagram showing two twelves, and saying they would be much better off with 15s. Bracing would be required in the box, significantly lowering the cubic feet. I've done more number crunching since that thread. With bracing and some beefy 15s like the one I have sitting in the garage, should come out to about 3cubes per sub.
Old Jul 2, 2008 | 10:36 PM
theunclesam's Avatar
And I just thought this thread was going to be a joke about 2girls 1cup.
Old Jul 2, 2008 | 11:47 PM
Strictly Scionized
LOLOLOLOL just about
Well back to the OP...either strapping amps or using a maxxlink, safest bet.
Old Jul 6, 2008 | 04:35 AM
XSNiper's Avatar
I am so happy I wasn't the only one that thought about 2 girls 1 cup...
Old Jul 6, 2008 | 05:09 AM
GammaTNT's Avatar
hahaha,
i should have named the title "1sub power by 2 amp" instead.
Thank for the help. I just read the manual, It said each VR1000 need 1 battery.
I don't think i will put 2 extra battery in my trunk.
Scion202
Scion tC 2G Aero & Exterior
Sep 5, 2011 07:25 PM
FamilyBox
May 19, 2009 04:03 AM
paul_dezod
476
Nov 5, 2008 02:09 PM
dziuniek
Scion tC 1G ICE & Interior
15
Aug 23, 2006 01:45 AM
NewSpectraBlue
Oct 8, 2005 06:52 AM
