Lil puffs of white smoke normal?
Old Jul 10, 2008 | 04:58 PM
08superwhite's Avatar
Default Lil puffs of white smoke normal?
I don't have the pcv/crankcase breather connected to anything. i just have the hose coming off of it. I noticed today that if I hold it up i can see little white puffs of smoke coming out. I mean they are very tiny. i can only see them if I hold it up against a dark background like the insulation on the hood. i never noticed before but I also never looked. Checked the oil, level is good and clean, everything else looks good. Is this a problem or am I paranoid.
Old Jul 10, 2008 | 05:11 PM
brett561tc's Avatar
its normal.
Old Jul 10, 2008 | 05:14 PM
ok, i just got nervous too cause at idle i noticed that my vacuum is only at 16 where it used to be 19, but I was having idle issues so i have 20 deg of timing pulled out, it corrected the idle problem but i wonder if that is what is causing my low vacuum. (i know i don't have any vacuum leaks, i already checked)
Old Jul 10, 2008 | 05:25 PM
youngflyer's Avatar
um white smoke, if im reading this right, it sounds like you have blowby
Old Jul 10, 2008 | 05:34 PM
Rawkerstatus's Avatar
ur fine.. you really should have it connected tho.. or atleast make some kinda capture device thin-a-ma-jig. sounds like too much to be blow by.. might be tho or just that the oil is hot.
Old Jul 10, 2008 | 06:43 PM
youngflyer's Avatar
well heres a sure fire way to tell if you have blowby. start your motor and let it get up to operating temp. pull your oil dip-stick tube out, if there is white smoke coming out, then you got some problemos!
Old Jul 10, 2008 | 10:15 PM
guttedtc0's Avatar
same thing happened to me..
thick white smoke coming from the crankcase vent.. excessive blow by
do a compression test.. your rings could be fried.
I also had the smoke coming from the dipstick while running
compression in cylinder 1,3,4 = 150 (normal)
compression in cylinder 2 = 70psi
I also have a spare block that detonated in cylinder 2.. let me know if yu have a problem with that cylinder
laforze
12
Feb 16, 2016 12:50 AM
mc1114
Aug 12, 2015 02:07 AM
us3r
Aug 1, 2015 03:59 PM
JoggerFogger
Photography & Video
Jul 27, 2015 09:34 PM
