2.0" drop/ Wheel Camber
Old Jul 15, 2008 | 03:14 AM
bballa709's Avatar
Default 2.0" drop/ Wheel Camber
I went in to the local spring shop and they were tellin me that if i did any 2" drop that i would need a rear camber kit. I was just wonderin if anyone has a 2" drop without a camber kit.
Thanks
Old Jul 15, 2008 | 03:17 AM
Coolwaterz's Avatar
with a 2" drop your going to need a camber kit or else your going to rip up your tires...
i heard with TRD 1-1.5" you dont need it.
Old Jul 15, 2008 | 03:18 AM
Yanki01's Avatar
ive had hotchkis springs for 2.5yrs and just installed rear camber links in the beginning of the year. i noticed a big difference in stance and will save the life of your rear tires. SOME people on here have gone to shops to where they can fix the negative camber back to stock specs. my local shops were unable to which is why i purchased hotchkis rear camber links.
Old Jul 15, 2008 | 04:47 AM
BuddhasTC's Avatar
there's a lot of people here with Stechs and most of them had said that getting it aligned was all that was needed. I personally have Htechs and the alignment was all that was needed...but it's not a 2" drop
Old Jul 15, 2008 | 08:58 AM
tcCALI's Avatar
this might be a really dumb question but here it goes. can you use the hotckis camber kit with any spring set-up?
Old Jul 15, 2008 | 09:02 AM
PartieBoiTc4's Avatar
i have almost a 2'' drop and i need a camber links. wear on my tires is uneven. i suggest to get the camber links just in case.
Old Jul 15, 2008 | 12:21 PM
Yanki01's Avatar
yes you can.
Old Jul 15, 2008 | 04:30 PM
yellowxhoodie's Avatar
i was on s-techs for 6 months with no camber kit or alignment and didnt see any irregular tire wear.
Old Jul 15, 2008 | 05:58 PM
Trivecta's Avatar
x2, cept I did get an alignment and its almost been a year now.
Old Jul 17, 2008 | 01:54 PM
boomshakadae's Avatar
x3 S-Techs for ever now w/ alignment and never have had irregular tire wear or a need for camber kit, although it has been suggested.
Old Jul 18, 2008 | 12:50 AM
Air2TheThrown's Avatar
Went with 2 years on Stechs. No problems because the guys that did the alignment knocked the camber back in its place. No camber kit needed here.
Old Jul 18, 2008 | 03:08 AM
davedavetC's Avatar
haha i think im one of the few people whos getting the camber links to run less camber (more neg,... im hoping for neg3*)
Old Jul 18, 2008 | 03:23 AM
Dr_Isotope's Avatar
Camber doesn't wear tires. Toe does. Adjustable camber links are for adding camber, not taking it away. I ran -2.5º in the front and -2.0º on my Honda for two years with no uneven wear.
Old Jul 22, 2008 | 08:21 PM
KrazyTc's Avatar
Correct me if im wrong but i was under the impression that camber is the tilt of the tire so if you have too much camper you'll be riding on one side of the tire more that the other. So if that where true then you would get uneven ware since its only using that oart of the tire. Also isnt toe the way your tire is pointing? I could be wrong but thats what i always told. But its been awhile since ive been in school.
Old Jul 22, 2008 | 08:24 PM
Dr_Isotope's Avatar
Every time the attitude of the car changes, the camber angle changes. It will not adversely affect tire wire until extreme angles are reached, like -7º. Toe angle will wear tires rapidly, as you are essentially driving across the tread of the tire, so it's constantly "scrubbing".
Old Jul 23, 2008 | 01:04 AM
KrazyTc's Avatar
Oh ok i see what you mean. I learn something new today...lol
Old Jul 26, 2008 | 09:13 PM
lakaikills's Avatar
Well i just got mine aligned today after a little over a month with sTechs. They said everything is fine. but the rears still look the same. ( the look unbalanced a little nothing major) Does anybody have a picture of a bad case of this. i guess "too much camber" im not sure if a have that right.
So should i just go ahead with a camber kit?
and if i do, is there any noticable performance upgrade? (handling)
Old Jul 31, 2008 | 02:59 AM
CSOCSO's Avatar
as far as i know my rear camber and toe is within spec ( i got 2 inch drop in the back and 17's) BUT on the front the camber is off by half degree so i need to get camber kit, well its only 30 dollars...
Old Aug 3, 2008 | 05:43 PM
errgelistic's Avatar
i have tein stechs for 2rys till i got an alignment . i had really bad tire wear on the inner side of the tire. after the alignment, dont know if it got better cuz i just bought new tires
Old Aug 3, 2008 | 05:57 PM
cavalierkid888's Avatar
I have hotchkis springs and I never got an alignment. I have slight negative camber (which I've heard isn't necessarily a bad thing, also confirmed by doc I above).
I rotate my tires every 5k miles (everytime I do my oil change) and I check tread wear every time with one of those little credit card meters you can pick up for free at discount tire. So far no noticable uneven treadware and its been 15k miles...
Just throwin that out there. Just seems to me like everybody is afraid of any neg. camber....
