2.0" drop/ Wheel Camber
#42
Originally Posted by tc-guy
fyi, rear camber is not adjustable w/o camber links.
yes, negative camber will wear tires out but very slowly. now with toe out, if it is bad enough ur tires could be gone within a few hundred miles.
on the one that SPC makes, all it is is a longer upper control arm that uses the stock adjustment bolt. that how it gets more adjustment. thats why it is cheaper than the hotchkis piece.
oh and to ur question csocso the only way ur gonna get your toe not to go out of adjustment is to probably weld your lower control arm toe adjustments together after you get the toe in specs
![Icon Tongue](https://www.scionlife.com/forums/images/smilies/icon_tongue.gif)
#44
i dunno. im just talkin out of my a$$ on that one. but in theory it could work. somehow the guy that did my alignment before i did it myself tightened my toe adjustments on the right side so much that it is permanently stuck in one position. i mean it is still in spec but that thing is basically welded together and it stays in spec so i dunno it COULD work.
#45
tc-guy you hit the nail on the head as far as the stock rear camber adjustment being just BARELY out of spec. Thats how both my rears are, like .1 out of spec. I'm on s-techs.
My buddy (certified tech at Hundai) did my alignment with me watching and we both tried to get it in spec but theres just no more room for adjustment.
Although i'm sure my springs have settled quite a bit since then. I used to be able to put a finger straight in the wheel well with a TINY bit of space, now it's snug to even do that. The rears have settled in even better than the front.
I was on Prada spec2's for a few thousand miles and had no uneven wear. Been on my Azenis RT615's for about 1100 and they are still 98%, can still read the Azenis on the chunk of tread in the middle.
#46
yea i think thats why trd made their springs 1.5" drop only cuz they did r&d and found that with that slight of a drop u can still get in into specs. i bet that if trd could get the alignment into specs with a lower drop they would have made the springs that way.
xdejablu3x
04-19-2017 03:44 PM
scionhawaii
13
06-19-2015 03:59 PM
kleecker
01-02-2015 08:09 PM
