Sputtering and hesitating
Old Jul 16, 2008 | 10:50 PM
NA_TC_817's Avatar
Default Sputtering and hesitating
well i got tuned this past saturday and as of monday my car started acting up the car would sputter and hesitate under boost
Old Jul 16, 2008 | 10:51 PM
guttedtc0's Avatar
AFR? Which EMS?
Old Jul 17, 2008 | 12:26 AM
NA_TC_817's Avatar
AEM F/IC and i dont have a wideband but its on the way as we speak
Old Jul 17, 2008 | 03:40 AM
thendawg's Avatar
Just curious does it get really rich (down to 10-11.5 afr) and sputter around 2krpm when under vacuum and partial acceleration? DOnt really understand this but i dont know if youd ever see this on a dyno tune - i had to pull fuel in this range to fix it, now it works great after a little tweaking
Old Jul 17, 2008 | 03:49 AM
aen's Avatar
aen
he probably won't know until he gets his gauge.
you're afr's are probably around 10.0 or lower and you are running really rich. past 2k rpm how is the car?
Old Jul 17, 2008 | 09:48 AM
guttedtc0's Avatar
take out a spark plug.. takea pic of the tip and post it
Old Jul 17, 2008 | 10:27 AM
paulky_2000's Avatar
I'd bet one of your pipes on the boost side has come loose.
Old Jul 17, 2008 | 02:54 PM
NA_TC_817's Avatar
pull the plugs and they are still good ... its my fuel map its running rich in boost and partial acc. it was doing this on the dyno but i thought the tuner would have fix it.
Old Jul 17, 2008 | 05:22 PM
05-RS1's Avatar
what was the a/f you were getting while on the dyno then?
Old Jul 17, 2008 | 05:24 PM
NA_TC_817's Avatar
to be honest im not real sure but i wanna say 11.5
Old Jul 17, 2008 | 07:48 PM
guttedtc0's Avatar
whats vacuum at during idle
Old Jul 17, 2008 | 07:57 PM
garabaldy's Avatar
This happens sometimes after a dyno tune, it is probably running rich, get that AFR gauge installed.
Old Jul 17, 2008 | 08:07 PM
NA_TC_817's Avatar
20 but my car seems to have hiccups and im running ngk 7s but on the stock gap cause autoparts store have no idea what a feeler gap is
Old Jul 17, 2008 | 08:08 PM
NA_TC_817's Avatar
it should be here friday so ill get it installed and post up the readings..
Old Jul 17, 2008 | 08:22 PM
B_Real45's Avatar
Did you buy the one with "-11" at the end of the model number? If so your gap is .44.
If you didn't, then we don't know what your gap is.. but the gap could be your issue.
Old Jul 17, 2008 | 08:49 PM
thendawg's Avatar
Just curious what should our plugs be gapped to? .040? Im using ngk iridium's that are -11 so theyre .044 stock i believe
Old Jul 17, 2008 | 11:03 PM
NA_TC_817's Avatar
i got the ngk B K R 7 E I X -11
Old Jul 18, 2008 | 12:06 AM
B_Real45's Avatar
Okay - try making a smaller gap.. try .35 first.
Old Jul 18, 2008 | 12:34 AM
NA_TC_817's Avatar
i dont have a gap tool and i know using a slider gap tool isn't very smart for iridiums .. and part stores around my area dont have a clue about the tool i would need
Old Jul 18, 2008 | 12:47 AM
B_Real45's Avatar
If you want, go out and buy regular copper plugs in 7 heat range and gap them down.
